NCRS-ish wheel question: date codes
Old Aug 17, 2016 | 03:12 PM
vettebuyer6369's Avatar
vettebuyer6369
Default NCRS-ish wheel question: date codes
I was looking at the date codes off my '69 Rallys and I noticed they matched each other, with Oct 1968. That seems like an early wheel. The car is a Nov, 69 car. This would be about 13 months prior.
I know NCRS only judges the spare's date code. It does not say in the JG whether 6 months prior is the max on wheels, per usual on many items, or up to a year like on some glass.
Anyone know this?
Old Aug 17, 2016 | 03:14 PM
vettebuyer6369
Photo 'cause we like pictures:
Old Aug 17, 2016 | 04:05 PM
Alan 71's Avatar
Alan 71
Hi VB,
I believe the typical 6 month span before the car's build date applies to wheels too.
Regards,
Alan
Old Aug 17, 2016 | 04:39 PM
vettebuyer6369
Originally Posted by Alan 71
Hi VB,
Regards,
Alan
Old Aug 17, 2016 | 09:33 PM
dmaxx3500's Avatar
dmaxx3500
I wonder if GM ran a batch of 1968 wheels and just used them,till they ran out,also does anybody have a 1970 car with 68 wheels?
Old Aug 17, 2016 | 09:44 PM
vettebuyer6369
AZ is '69 only though, right?
Old Aug 17, 2016 | 09:48 PM
ed427vette's Avatar
ed427vette
AZ is used through the entire run except for the 68 year from what I understand.
Old Aug 17, 2016 | 09:53 PM
ed427vette's Avatar
ed427vette
I have a 69 that was built on jan 11 69 that has the original wheels and they are all dated Dec 20th. I also have a Feb 18 69 built car that has 3 original wheels and they are all dated Jan 15.
Old Aug 17, 2016 | 09:55 PM
vettebuyer6369
Oh, thats right, I have a '71 wheel with AZ. Duh.
Old Aug 17, 2016 | 10:20 PM
jhudec's Avatar
jhudec
That could also be a 78 wheel. Early 69, dated 68 wheels are not common. Is there a BB sized piece of weld on the outer rim?
Old Aug 17, 2016 | 10:34 PM
vettebuyer6369
How "not common?"
You mean this one?
Old Aug 17, 2016 | 10:59 PM
jhudec's Avatar
jhudec
That looks like it.
They are worth whatever someone is willing to pay.
Most likely a little more than larger date batch runs.
Old Aug 17, 2016 | 11:03 PM
vettebuyer6369
The font is different than this '71 as well:
Old Aug 18, 2016 | 12:03 AM
ed427vette's Avatar
ed427vette
You can also tell by the font. His are definitely from 1968. Sometimes people make the mistake of grinding off the weld thinking they are cleaning up the rim....
On 1978 rims, the 1's are just a staright bar for the day/month date font with no bar across the top. Also the 8 is much smaller. The K18 looks like K-1-8 with the dashes between for 1978.
Although Vettebuyers K18 looks like a straight bar number 1, its only because the stamping did not come out complete. You can see the cross bar on the "21". On a 78 rim it would have been just a straight line (bar).
Also the K18 is a unique font in 1968 made rims. When they went to K19 in 1969 the K looks like your 1971 font on most rims. The 1's still had the cross top bar type font on both the K19 and for the actual year date numbers like those on the 68 rims. It should also be noted that there are two types of K19 year fonts. Some early K19 stamps had no dashes but they overlapped with some stamps that had dashes. The ones that had no dashes also looked bigger in font size similar to the K18. The second type K-1-9 were smaller and thinner like the 71 rim showed above.
I have a 1978 rim I can take a picture of to illustrate the difference. Its much different.
Here is the 78 rim
Old Aug 18, 2016 | 01:14 AM
vettebuyer6369
Thanks for the input, guys.
To NCRS-ish wheel question: date codes
