Bolt needed
Old Aug 21, 2016 | 03:20 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Default Bolt needed
Hey all,
Well my cataloging system failed me as I have lost bolt numbered 397-1. Of course, it is item #5 in the AIM that has the referenced part number cut off by the terrible scan job.
Does anyone know this bolt size? Even better - anyone know the part #?
This for a '69 w/ an M-20.
Old Aug 21, 2016 | 06:34 PM
DUB's Avatar
DUB
Are you worried about it being the same head marked bolt that GM used ...or just one that will deserve its purpose???
I would imagine the bolt is a 3/8-16...but it also could be a 5/16-18...and IF you noticed in what you posted. The EXACT same bolt is used for the side cover. If you still have one...use it to compare to due to all of the bolts are the same thread..
This can be easily picked up at a hardware store....if you are not worried about the head marking.
DUB
Old Aug 21, 2016 | 06:39 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
5/16-18 x 3/4 . I just threw a bunch of rusty ones in my scrap bin.
Old Aug 21, 2016 | 07:07 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I just looked in my 69 AIM and #5 says, "Part of trans asm". There is no part number.
From this info, I would say you should use the same size bolt as the other cover bolts on the forward bracket - 5/16-18 X ¾". The rear bolt should be the same size and the other 3 tail housing bolts. All I could find on that is 7/16-14 -no length given.
John
Old Aug 21, 2016 | 07:17 PM
Alan 71's Avatar
Alan 71
Hi,
I believe the bolt you identify as 397-1 is 3/8"-16x1-3/4", grade 5.
Regards,
Alan
Old Aug 21, 2016 | 10:06 PM
LeMans Pete
All,
Thanks for the responses! I had also cross-posted this on the NCRS tech board and Joe L. also responded with 3/8-16 X 1-3/4", GM part #9419054.
Old Aug 22, 2016 | 05:11 PM
Pop Chevy's Avatar
Pop Chevy
Yep, that's right . I was looking at the other bolt.
Old Aug 22, 2016 | 05:37 PM
DUB's Avatar
DUB
Originally Posted by LeMans Pete
All,
Are you looking for an original or a function replacement?
YES...but both bolts in the illustration are the same bolt. They are both part number 5.
DUB
To Bolt needed
