Wiper Door
Old Sep 28, 2016 | 10:39 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Remember early 68s are different from late 68s. Early 68 go low to high across the column.
Old Sep 28, 2016 | 07:48 PM
Rescue Rogers
Pics are from floor looking up. Not great but its visible. The harness is clearly not long enough to make it to the top of the speedometer
The tape id coming off the fiber optics but you can see the harness behind it
Brass long nut is the speedo trip reset. The wedge is the top of the column
Steering column on left
Steering column on right. You can see the harness and optics above the tach cable. The spliced wiring is a ground that I had to extend but needed it removable
Coming out of steering coumn going above the tach cable
Old Oct 1, 2016 | 06:14 PM
swag's Avatar
swag
Hi, just an update on the project. So, I installed the new solenoid and it isn't working. Also, noticed the previous owner removed the filter from the vacuum source.
Is it common to get a bad part like the solenoid? Wiper door opens fine when I bypass the solenoid. i.e. hook it back the way the previous owner set it up.
I am at a loss on what to look at next?
What do you all suggest?
Thank you!
Old Oct 1, 2016 | 07:24 PM
loup68's Avatar
loup68
Army
Alan and Rescue Rogers are correct, in that the 68 dash harness goes under the speedometer and the tachometer. This was changed in the MY 1969. Lou.
Old Oct 1, 2016 | 09:36 PM
Rescue Rogers
Check wilcox site for testing the solenoid. It could be bad or not getting the signal/ power
Old Oct 1, 2016 | 10:56 PM
7T1vette's Avatar
7T1vette
Have you verified that 12vdc is being sent to the solenoid by the wiper switch when it is turned ON? It could be a problem with the wiper switch, its wiring, or that power is not even getting to the wiper switch.
P.S. I have seen that the wiper switch CAN be installed upside down...in which case it will not operate correctly. Check the drawing in the AIM to assure that it is assembled correctly.
Old Oct 14, 2016 | 09:15 PM
carriljc's Avatar
carriljc
Default Thanks for all this info...
Mine had been working wonderfully for years and then yesterday I went to take a drive after a couple of weeks of not using the car.... well, the battery was dead. I removed the battery and slow-charged it overnight.
Today i went out there and installed the battery...as I was hooking it up I heard "something" pick up. Turned out to be the wiper solenoid that sits under the dash.
NOW I have to figure out why it was being energized while the car is turned off.
Any quick pointers before I dive into troubleshooting?
Old Oct 14, 2016 | 09:19 PM
Rescue Rogers
Check the overide switch under the dash. I know on a 68 it provides a ground to my system that trips the solenoid to release the vacuum, or something. My switch will drain my battery if left on. I put a dot of white paint on it so I can tell its position easily.
Old Oct 14, 2016 | 09:46 PM
carriljc's Avatar
carriljc
Default Thanks, and I found the 68 wilcox troubleshooting guide...
I'll check that overide **** (I gather full counterclockwise is "off" as you look up??).
http://repairs.willcoxcorvette.com/w...-schematic.pdf
Meanwhile, per the wilcox guide above, the wiper solenoid on a 68 is sitting there grounded and waiting for 12 vdc from the BROWN wire when the wiper motor is running. Well, my wiper motor is NOT running and obviously mine has 12 vdc on the BROWN wire at all times so I have to go figure out why.... ?????
Old Oct 15, 2016 | 09:02 AM
Rescue Rogers
Ive read its the exact opposite. Always has 12 vdc waiting for ground. I've been known to be wrong before so Im not surprised if I am.
Since your battery is fresh, did it start and do the wipers work?
Old Oct 15, 2016 | 11:52 AM
carriljc's Avatar
carriljc
Default 68 is different per Wilcox info...
Here is the text from that link above concerning the wiper solenoid; note that on the 1968 the ground is constant and it is sitting there waiting for 12 vdc from the wiper motor running:
I understood that the 1968 was a bit different, but since mine has mostly worked well I had not investigated. Many thanks to Wilcox.
Now I have to go figure out why mine decided to be energized.
To answer your question:
YES- the car started fine.
NO- the wipers are not working.
Old Oct 15, 2016 | 07:52 PM
Rescue Rogers
Yes I did get that part backwards, thanks. So what exactly isnt working, the door not openning or the wipers not wiping? There is a trouble shooting addendum in the aim to help diagnose which part has failed. Willcox might have that posted as well
Old Oct 16, 2016 | 10:34 AM
  #33
carriljc's Avatar
carriljc
Default I will start the troubleshooting this upcoming week...
Thanks for the pointers.
My initial investigation was to just find out why I had constant current draw from the battery.
I really have to go find out why the power lead to the wiper door solenoid has power when it should not. Doesn't sound too terrible.
I did manage to redraw that vacuum diagram so that it makes sense to me and get a better understanding of how the system works.
I have a vacuum pump so I should be able to do some troubleshooting without running the engine.
I only started the engine to ensure it started. I did not try to run the wipers with the car in the garage....gets mighty exhaust stinky pretty fast. Of course neither the wiper door nor the wipers worked later with just the key in ON (should have had some residual vacuum), but I did not investigate further. Just put it away with the wiper door solenoid, and battery, disconnected.
Old Oct 16, 2016 | 04:27 PM
  #34
Rescue Rogers
I have a vacuum pump that works off an air compressor. It was pretty cheap. I may invest in an electric one from harbor freight. They run the $100.00 but should be on sale or available with the discount coupons.
Good luck
Scott
Old Oct 18, 2016 | 10:05 PM
  #35
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
1968 is ground waiting for power, 1969-1972 is hot waiting for ground.. More genius headaches for 68 owners from the GM gods.
