How do you clean your convertible back window
Old Sep 5, 2016 | 08:47 PM
Vet76te's Avatar
Vet76te
Default How do you clean your convertible back window
How do you guys clean your convertible back window without scratching it? What product do you use and what method?
Old Sep 5, 2016 | 08:55 PM
mortgageguy's Avatar
mortgageguy
I use Mequair's plastic cleaner. I think it's called PlastX. Removes haze scratches etc. really cleared up my old window.
Old Sep 5, 2016 | 09:11 PM
Vet76te's Avatar
Vet76te
My top is new.....I just want to keep it looking that way. Don't want to scratch the window up.
Old Sep 5, 2016 | 09:53 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Similar to cleaning eyeglasses that have "plastic" lenses.......rinse/spray with cool water to remove as much dust/grit as possible......then wash with soapy water/rinse again.....blot dry with a very soft absorbent cloth.....apply quality "plastic polish" with a very soft clean cloth.....wipe clean with ANOTHER clean soft cloth....use a soft cloth to protect the window when lowering the top.....
Did I miss anything....Ya'll?
Old Sep 5, 2016 | 10:04 PM
SteveG75's Avatar
SteveG75
Plexus plastic cleaner/polish + microfiber cloth.
Old Sep 5, 2016 | 10:09 PM
redrdstr72's Avatar
redrdstr72
+ 1. Plexus is awesome. Use with a soft microfiber cloth and you'll love the results...
Old Sep 6, 2016 | 12:56 AM
ddawson's Avatar
ddawson
I use Ragtop products.
http://www.autogeek.net/raggtopp-con...indow-kit.html
Old Sep 6, 2016 | 01:24 AM
slickfx3's Avatar
slickfx3
https://www.novuspolish.com/
Old Sep 6, 2016 | 07:38 AM
LS4 PILOT's Avatar
LS4 PILOT
I don't
It so rare it ever goes up
Old Sep 6, 2016 | 10:28 AM
Tooch1's Avatar
Tooch1
I too use Plexus once a year. The rest of the time just spray with plain water in a spray bottle until it beads up and starts running down the window, then I just run a soft cotton towel lightly over it until dry.
Along these same lines, while at a local car cruise a couple of weeks ago I was talking with a guy who told me he used the ( 'headlight cleaning kit' the auto stores sell to remove the dull,fogging on the headlights of today's newer cars that set out in the elements), on his very original BB 69 roadster. He said it was yellowed very bad. It is the original dated window. I couldn't believe he tried it, I would have been afraid to try it. Has anyone else tried this technique?
Old Sep 6, 2016 | 01:00 PM
bj1k's Avatar
bj1k
Most of the replies here have been how to restore a window after it has been damaged . The answer to his question is how to clean the window of a brand new top without damaging it. First never wipe a dry window . When I wash my car which is very seldom , I first hose the top and window . Then with some warm water containing very little Dawn soap and a soft cotton cloth using very light pressure I clean the window first then the top . Lightly dry the back window first with a cotton cloth then the top . I've used this method for over forty years on all of my convertibles and never had window damage. The tops go bad at the same time as the windows. Now if you repeatedly fold the top down you will get damage sooner . If you do put the top down make sure you use one of the window pillows that the vendors sell but only use it when the back window is free of dust because the rubbing action of the pillow will scratch the window. All in all the windows are not hard to take care of if you take some care.
Old Sep 7, 2016 | 06:09 PM
7T1vette's Avatar
7T1vette
Back in the day, I used Simonize car wax to clean and protect the plastic window...inside and out...every time I washed the car. It also helped to block UV rays that tend to age/harden/darken the platic window.
Today, there are many polymer polishes that could do similarly. I think using wax does help keep the plastic flexible; don't know if the polymer polishes will aid flexibility or not.
Whatever you use, if the top will be up and in the sun on occasion, make sure the product will block UV rays.
Microfiber towels are GREAT for washing/drying that plastic window. Flush dirt off with hose FIRST, then wash with MILD soap (not detergent), and dry with microfiber towel. Put protectant on inside AND outside of the plastic window.
Old Sep 8, 2016 | 03:18 PM
dochorsepower's Avatar
dochorsepower
Sun is the big enemy. Keep it stowed.
Old Sep 8, 2016 | 11:01 PM
bj1k's Avatar
bj1k
It is just as bad to leave it down all of the time since it will get permanent wrinkles and creases which lead to tears.
To How do you clean your convertible back window
