coil testing
Old Sep 15, 2016 | 02:59 PM
chrissy t's Avatar
chrissy t
Default coil testing
I have been trying to check resistance on my coil. All the info I have found talks about ohm values for a coil with external resistor. Are the values the same with an internal resistor? if they are different, would someone know what ohms should be? thanks, rob
Old Sep 16, 2016 | 04:36 PM
MelWff's Avatar
MelWff
first thing you have to tell us who manufactured the coil and possibly the part number
Old Sep 16, 2016 | 07:10 PM
chrissy t's Avatar
chrissy t
the coil was sold by advanced auto and there part # is E40P . The coil has the numbers 1305 on the outer case.Hope this helps, thanks,Rob
Old Sep 17, 2016 | 10:06 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You didn't say what year the car was, but I ran the part number and I'll assume it's a 1974 or older car.
What problem are you having to check the new coil?
Normal resistance would be around 1.5 to 1.7 on the primary side. On the secondary side with your meter in the 20K setting you should read 11.0 or higher and anything less would be an issue.
Willcox
Old Sep 18, 2016 | 02:03 PM
7T1vette's Avatar
7T1vette
Ignition coil "resistance" values are resistance measurements for primary and secondary windings in the coil. They do not include the external resistance when making those measurements.
The coil may state that it is for "external resistance" ignition systems, but that has nothing to do with making coil resistance checks.
Old Sep 19, 2016 | 09:30 AM
gungatim's Avatar
gungatim
a few seconds typing in the item to Advanced auto's website reveals the following (you're welcome):
CARQUEST by BWD Ignition Coil
Part No. E40P
The ohm rating of the primary resistance is 3.25-3.50 and the secondary resistance is 7700-9500
specifications:
Connector Gender: Female
Contains Internal Resistor: No
Contents: Ignition Coil
Mounting Location: External
Number of Terminals: 2
Number of Volts:12
Requires External Resistor: No
Terminal Gender: Male
Terminal Type: Stud
Old Sep 19, 2016 | 05:02 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Is this the same coil from your previous thread?
Old Sep 19, 2016 | 06:51 PM
chrissy t's Avatar
chrissy t
Yes it is. Still trying to settle this problem. Thanks for all the replies.
Old Sep 19, 2016 | 10:51 PM
69427's Avatar
69427
Looking at the specs gungatim provided (), the (maximum) primary current [13.2v/3.25Rcoil=4.06A] is slightly less than the original setup, using the numbers from Wilcox [13.2v/(1.5BR+1.5Rcoil)=4.4A or 13.2v/(1.5BR+1.7Rcoil)=4.125A], so coil primary current shouldn't be an issue for the points.
I don't recall if the question got answered before, but are you confident that the condenser is not damaged or defective?
Old Apr 15, 2020 | 05:22 PM
Sammy T's Avatar
Sammy T
Willcox
Sorry to dig up an old thread...but can you explain why 11k or less on the secondary side is bad given the factory spec of 3k-20k? My current coil is 1.8 on the primary and 6450 on the secondary.
To coil testing
