Chandler..the original floats on cars that are the age of ours have a bad tendency to get loggy and unresponsive..The upgraded brass float is a great upgrade for the original carb rebuild.
As you progress and get the old Rochester cleaned, rebuilt..run only ethanol free gas in your L48..Your car will thank you for the extra cost of good fuel..Alcohol is a killer for carburated engines..lawnmowers, chainsaws, old cars..
I am fortunate that I found an older fellow with 40 years of good experience with the old carbs who did the work on my Rochester carb very well..There should be some local men who can do the work properly and right on your carb..Check with the collector car and hot rod clubs where you live..
Beyond that..Lars and a few others will do the work on your carb..but it'll take time and SOMEONE still has to remove and then re-install the rebuilt-renewed carb and set and adjust ALL properly for the finer tuning-timing issues..Jim
............Beyond that..Lars and a few others will do the work on your carb..but it'll take time and SOMEONE still has to remove and then re-install the rebuilt-renewed carb and set and adjust ALL properly for the finer tuning-timing issues..Jim
THAT'S the "stumbling block" with the Rochester Q-Jet, the adjustments. Doing a "rebuild" of one of them, while more complicated than a Holley, still can be accomplished by a reasonably skilled person. But doing all of the adjustments that are required, is where it gets really tricky.
Since 1958, I've lived in the Rochester, NY area, home of Rochester Products, the Q-Jets' birthplace. In the mid 60s through the late 70s, I had a neighbor who was both a drag racer, as well as a Rochester Products line technician. He taught me a lot about carbs, provided me with a number of RP tech manuals, and I've successfully rebuilt several Q-Jets. However, the last time I touched one, was around 1993, and although I might be able to go through one, I certainly wouldn't look forward to it....
Leadfoot4:
Well said...vac advance, choke, idle, lean-rich..and then timing..plugs, wires, dist..A whole world of small fine adjustments to get these older cars running their best..and efficiently..Jim
From another point of view, after Lars rebuilt my Q-Jet, I bolted her on, hooked up the linkage, switched choke wire and primed the carb. Fired right up, warmed up and idled nicely. I adjusted the idle speed a little and that was it.
And that's EXACTLY what I was getting at. A Q-Jet is both sophisticated and somewhat complicated, with a number of adjustments and settings that need to be done CORRECTLY, while the carb is being rebuilt. Unless you're experienced with this, it can be a nightmare. You sent your carb to an experienced and capable man, therefore you were able to just "bolt it on", and it worked properly.
The fuel spilling maybe be because the needle valve was stuck open, by debris that somehow made it pass the filter. The carb filled with fuel leaking out the accel pump hole and wherever else, as well as shutting off the mtr.
Great that you have an original carb and even better that it appears to be untouched.
I've had www.custom rebuiltcarbs.com, that are in New Jersey rebuilt a Q-Jet from a PC that I was working on with good results. Custom Rebuilt does great stuff, like repair the primary side of the throttle shaft, by inserting bushings to eliminate wear that occurs over 28 years of use. They bench test all their work assuring that it functions properly, before sending back to it's owner.
Think that your fuel spilling was because the needle valve was stuck open, by debris that somehow made it pass the filter.
