C3 rear compartment light replacement?
Looks like it should load from the top of the bin hole so the plunger pushes down when the door shuts and the ring l on the button should bear on the top of the bin edge.
But one of the connectors is too big to pass thru the hole, as is the socket body!
Please help solve the puzzle.
Thats how it should fit though, maybe wrong part?
The assembly should pass through from the top, without the bulb installed - that goes in from the bottom once the assembly is in place, if I remember correctly. If the wire connectors won't go through the hole, you must have the wrong part.
Only the hole in the bin frame is too small to fit the bigger connector, and then the body of the switch (even with the bulb out).
Don't want to enlarge the hole and permanently alter the existing part, until I know that the switch is correct.
I left a message at "Lectric Limited" (Corvette America's vendor for the part), to see if they have specs for the correct hole size for their part to fit into and then to engage.
C.A. didn't have design specifics.
I am assuming the silver collar sits on top side of the hole, with the spring ears engaging the underside of the hole.
I want to avoid overdoing it on the hole size, as I can envision ending up too loose, and having the bulb burn/melt the lens if knocked out of alignment.
The body of the light assembly should go in with a fairly firm interference fit, if I remember correctly. The wire connector that won't fit through could likely be removed from the wire, if you had to.
I wouldn't start enlarging holes, especially if you've got an original rear compartment - shouldn't have to do that.
I could remove it and re-glue them together after feeding the switch up from underneath, but - again - would like to understand from the company what the proper install procedure is.
(edit: Just heard back from Lectric Limited, maker of the part, and they indicate the hole size in the Rr Compartment Frame lip should be 0.625 (5/8") for proper clip engagement. And that it is designed be installed downwards from the top with the bulb removed. I will need to go home and measure mine, but wondering if anyone else has an undersized hole here?)
It sounds like you will need to enlarge your hole. If that's the case it will be no big deal. Just go slowly and keep test fitting the light fixture. When the connectors fit through that should be big enough to then fit the fixture.
I used my old frame hole as a template but made it a bit smaller on purpose.
Did the new light look like the old light that came out of The compartment? That's the only thing that makes no sense to me. If the old light was original than the new one should fit. Same with the connectors. How did you get the old one out? Did the connectors come out through the hole also?
ED
The old switch was in pieces and I found it at the bottom of the jack compartment with just about anything else you could imagine EXCEPT a jack! Various nuts and bolts, cigarette butts, car wash tokens, a wheel bearing, ["and your angry eyes....."], lots of sticky stuff on the bottom of the compartment, etc. etc.
I'll have to retrieve it from the trash to see how it lines up to the new one, and to the existing hole.
On my 71 the light housing inserts from the top with the bulb removed.
The 2 connectors just fit through the hole one at a time.
Regards,
Alan
Bubba speaking…. "can the corners on the larger connector be 'trimmed' a bit so it'll fit through the existing hole?"
Here are the connectors in the jack compartment.
ED
Good luck with your resto. This forum is a true resource and full of great info from guys that have been were you are now. I've learned more here in the last two years then I have in the 20 before that.
Sincerely,
Ed
Also, put any nuts and bolts you find in a bag. They may go to something and having anything that might be original is good. If they do go to something, you'll know when you get to it. You can pretty much find what the "correct" bolt goes to by looking it up on the net or even asking here. Then you can match up what might be missing somewhere down the line. Some of us actually go out of the way for the proper headmarks when possible........just part of the sickness...or cure depending on how you look at it.
I ended up opening up my 1/2 inch hole to the prescribed 5/8 inches and the unit fit snugly in. The collar ring snapped to engage in place.
Pretty happy with the final result even though I had to improvise a bit.
Wondering if anyone knows the definitive hole size of the original desgn.
Also should the holes in the bottoms of the battery and jack compartments be open or plugged? I can see the ground through both.
Also also, any science behind the need for a seal around the battery door? There is some corrosion powder around the lip in some areas.
The circular drain holes in the bottom of the compartments should have a plug. You can see one in Alan's post #11, above, right hand side. The battery compartment seal was for vapour, etc., from the batteries of the period, which were more prone to leaking than modern designs (I believe). I'd put the seal on regardless. The battery compartment also had two rubber hoses that connected to the battery and vented to atmosphere under the car.
Cap hose trivia…
The 2 hoses were a different length to compensate for the caps' positions on the battery.
One hose was smooth and the other ribbed so the line worker knew which was which.
The end of the had a very sharp cut on it. I've HEARD that this was to create some small amount of 'venturi effect' so the gases would be drawn out of the battery.
Regards,
Alan
