1968 Wiper problem
Old Oct 28, 2016 | 11:08 AM
SIXTYTWO's Avatar
SIXTYTWO
Originally Posted by Dave J
My Great Karnak long distance diagnosis tells me that your actuator has a big leak in the BACK side port. If your door will open only partway, there is a reason. Put a vacuum pump on it (under the large dust boot) and check if it will hold vacuum.
I attached a vacuum line to the rear of the canister and got no door movement. Also with that vacuum line attached to the rear port I felt a vacuum draw at the front port. Does this indicate a vacuum leak?
Old Oct 28, 2016 | 11:15 AM
Dave J's Avatar
Dave J
Does this indicate a leaking canister?
May sound vague, but possibly. The internal diaphram must go to it's end of travel for any passage of vacuum through it to say it is the problem. If it cannot move to the front or rear and you feel vacuum at the opposite end, it's toast.
Old Oct 28, 2016 | 02:33 PM
carriljc's Avatar
carriljc
Default Thanks for the pointers...
I can do this to test my wiper door actuator also
Originally Posted by 530planeman
Rich
The center hose on the relay down in the fender should have vacuum when car is running .turn wipers off in the down position and pull the hose off the center of the relay and with engine running pull both hoses off the canister that opens the door.use the hose you took off the relay to open and close the door by moving vacuum source from front to rear of the canister.
Wes
Old Oct 28, 2016 | 03:01 PM
530planeman's Avatar
530planeman
Sounds like vacuum canister has a ruptured diaphragm
Wes
Old Oct 28, 2016 | 03:41 PM
SIXTYTWO's Avatar
SIXTYTWO
Wes
That's what I'm thinking too. Ordered one a few minutes ago.
Rich
Old Oct 30, 2016 | 10:59 AM
carriljc's Avatar
carriljc
Default where did you order actuator from?
Mine has about the same symptoms. After I do the vacuum hose test I may have to order an actuator. I bought mine with small actuator and the curved tube (I'll look again, but looks like a 72?). I'll just get the same thing since it's worked fine for like 32 years.
Rich
Old Oct 30, 2016 | 02:55 PM
SIXTYTWO's Avatar
SIXTYTWO
I bought mine from Ecklers . They're selling them on e bay, $118.00 and free shipping. I think I saw the other style too.
http://www.ebay.com/itm/172152425770?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Nov 22, 2016 | 04:36 PM
SIXTYTWO's Avatar
SIXTYTWO
http://www.ebay.com/itm/172152425770...%3AMEBIDX%3AIT
Just to finish the thread, I bought the new vacuum canister and finally got around to installing it today. It took about 6 minutes and now all is fine, wipers work great.
I'm thinking about having my original canister restored to keep the car as original as possible. I found an ad in the NCRS Driveline for a restoration service for the canister. I need to call and check the price.
I also pulled the radiator out to have it repaired so that ate up some time but it's back in now so we'll see what else needs attention after sitting for years.
Thanks to all who helped with the wiper door problem. Rich
