upgrading my seats
Old Nov 10, 2016 | 07:05 AM
Corvetteoz's Avatar
Corvetteoz
Originally Posted by ddawson
Nope, I went Pontiac.
Forget the seats, what type of steering wheel is that? Looks much more driveable steering wheel than my original steering wheel on my 72.
Old Nov 10, 2016 | 11:22 AM
ddawson's Avatar
ddawson
Just a standard aftermarket wheel from Zip, Ecklers etc.
Old Nov 11, 2016 | 04:27 AM
Corvetteoz's Avatar
Corvetteoz
Are these the ones?
https://willcoxcorvette.com/corvette...e-68-82-exc-76
Old Nov 11, 2016 | 12:19 PM
ddawson's Avatar
ddawson
Originally Posted by Corvetteoz
That's the one.
Old Nov 11, 2016 | 05:15 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
i put 3500 miles on my vette this summer, i dont think theyre that good.
Old Nov 11, 2016 | 11:39 PM
Corvetteoz's Avatar
Corvetteoz
That's the one.
In regards to the steering wheel. Are they just a simple changeover of the steering wheel itself? No need to change any other parts like the boss or horn cap?
Old Nov 12, 2016 | 12:41 AM
Lobzila's Avatar
Lobzila
I picked up a set of C-5 full power seats and was able to modify them to fit down as low as possible in my 68. At 5-08, its not a problem for me but taller people will have problems unless the t-tops are off, but I ran into other issues I did not think about. When I put the seats in, the huge steering wheel was hitting my thighs. Well to fix that, I thought I would swap in a tilt tele steering column from my guy who has a warehouse full of Vette parts. Then find out that Chevy did not make a tilt tele column for the 68. Got a tilt column from Flaming River and new smaller steering wheel. Also replaced and upgraded the seat belt to a shoulder harness type from a boneyard. As the replacement seats needed to be recovered, I found a local shop that did a great job and had them put the C-3 logo on the headrest. They were cheaper than buying the new covers online and doing it myself.
A bit pricey in the end and some hair loss on my end getting it all to fit, by my car is pretty far from original now anyway.
But far and away way more comfortable than the stock seats the 68 came with.
Old Nov 12, 2016 | 07:43 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Originally Posted by redcruz1120
I went with Pontiac Fiero seats. Mr. Mike was able to accommodate my father's signature into the leather. They are not uncomfortable to me and they fit like a glove.
Those seats look great! Where do you find used Fiero seats? Junkyard?
Old Nov 13, 2016 | 07:11 AM
Corvetteoz's Avatar
Corvetteoz
Sorry to go off topic a bit guys.
I ordered the steering wheel so hopefully it is a simple changeover.
Old Nov 13, 2016 | 11:02 AM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
Exactly the place. A junkyard. as long as the recliner mechanism/spring is good all else doesn't matter if you go with MR. Mikes seat covers.
Old Nov 13, 2016 | 11:43 AM
ddawson's Avatar
ddawson
On my 69 it was just pop the horn button off and remove the I think 6 screws. Then hang the new wheel and reinstall the screws.
Old Nov 13, 2016 | 02:02 PM
Rescue Rogers
good luck finding some in decent shape. The problem is the foam provides all the support, no springs. i called wrecking yards all over my area, none available. i would rather have them instead of my C5 seats
Old Nov 13, 2016 | 09:50 PM
  #33
GUSTO14's Avatar
GUSTO14
Originally Posted by LT1M21Vette
Anyone ever installed Recaro seats in a C3?
Yes, I installed a set of Recaro LS seats (originally purchased in 1979 for a Mustang) in my 1973 convertible.
I installed them in about 1999 and did a frame off on the car a few years later. At that time I redid the original seats and reinstalled them in the car. Seats are just waiting on another project!
As you may know the Recaro's use a somewhat universal mounting system that you just have to purchase a separate set of brackets for to mount in your specific car. The Mustang adapters wouldn't work in the Corvette so I had to purchase a different set of adapters. I ended up losing about an inch of headroom which was a bit much for me. Because the back adjust **** (lower right side of the right seat above) hit the door panels, I reversed the seats so that the ***** were above the center console. Otherwise fit was good and the seats are incredibly comfortable.
Good luck... GUSTO
Old Nov 14, 2016 | 07:22 AM
  #34
Corvetteoz's Avatar
Corvetteoz
Awesome thanks mate
Old Nov 14, 2016 | 10:28 PM
  #35
C3 Stroker's Avatar
C3 Stroker
I went with Pontiac Fiero seats.......
Those look great!
How does the weight compare to early C3 seats?.......Lighter,...heavier....?
Old Nov 15, 2016 | 07:26 AM
  #36
Dream Theater Fan's Avatar
Dream Theater Fan
2015 C3 of the Year Winner
Installed C6 seats in mine. I had to make my own brackets.
Old Nov 15, 2016 | 09:18 AM
  #37
74Ken's Avatar
74Ken
Originally Posted by C3 Stroker
Those look great!
If I remember correctly, I think the Fiero seats were lighter than the originals.
The originals to me were like sitting on a board with a little bit of padding. No arch support. I slid around on them too in corners.
To upgrading my seats
Old Nov 15, 2016 | 10:30 AM
  #38
pirate21svl's Avatar
pirate21svl
I installed these and are very comfortable. Got them through the same place that sales the shark bite suspension. Speed direct I think
Old Nov 15, 2016 | 11:16 AM
  #39
slofut's Avatar
slofut
C6 in mine, electric, '84 tilt column, '71 steering wheel. 5' 8" tall, fine for me. Sit a bit higher than stock. Seat heaters too!
IMG_3271 by Bill Smith, on Flickr
Old Jun 27, 2017 | 12:16 AM
  #40
Retcwby's Avatar
Retcwby
I would like to replace the seats in my 1979. there is no head rest to speak of, if I lean my head back, I can't see out properly.
