Fuel pump Repair
Old Nov 14, 2016 | 01:28 AM
wallifishrmn's Avatar
wallifishrmn
Default Fuel pump Repair
Had the original fuel pump from my 1971 LT-1 rebuilt. Works great--only problem is a very small leak at the base of the nipple where the fuel line attaches. Any suggestions on what to use to seal the leak.
Old Nov 14, 2016 | 04:06 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Have you tried to loosen and tighten the fuel line a few times? If that didn't work, I'd try replacing the carb to pump line.
Fuel leaks aren't fun.
Bob K.
Old Nov 14, 2016 | 10:38 AM
wallifishrmn
It's NOT the connection that leaks. It is the area where the square connector at the top of the fuel pump connects to the fuel pump body. There is a seam around its base where the leak is. Will JB weld work?
Old Nov 14, 2016 | 12:58 PM
ballen06's Avatar
ballen06
I would not trust JB weld on your fuel pump..
Purchase a new pump and don't take the chance of a future leak.
I don't think a proper repair of your pump would be cost effective ...
Just my opinion .. maybe others have had the same experience.
Good luck
Old Nov 14, 2016 | 02:11 PM
MelWff's Avatar
MelWff
why arent you sending the pump back to the rebuilder?
Old Nov 14, 2016 | 05:23 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
your playing with Fire... replace it.
Old Nov 14, 2016 | 05:28 PM
wallifishrmn
Repairer was in his 80's and has retired. Am looking at sending it in to Arthur Gold for repair
Old Nov 14, 2016 | 05:50 PM
Alan 71's Avatar
Alan 71
Hi w,
Last time I talked to Gould they were 'getting ready' to start restoring 'crimped bowl' fuel pumps.
It would certainly be a good thing if they have finally begun!
Please post what you find out!
Regards,
Alan
To Fuel pump Repair
