Body Mount Kit - Recommendation
Old Nov 17, 2016 | 10:40 AM
nix1981's Avatar
nix1981
Default Body Mount Kit - Recommendation
I'm looking to the forum for a body mount kit recommendation for a 1981. I suspect they're all about the same, and the prices seem to vary from $100-$140 and poly vs rubber etc.
Who's got the best kit for best price - Wilcox, Paragon, Zip, Corvette Central, etc? Thanks for your thoughts in advance!
Old Nov 17, 2016 | 10:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by nix1981
...Who's got the best kit for best price - Wilcox, Paragon, Zip, Corvette Central...
Take your pick. ZIP is in Mechanicsville. Might be close enough for you to drive over and purchase over the counter.
Old Nov 17, 2016 | 02:24 PM
nix1981's Avatar
nix1981
Good catch! Zip is about 2 hours away, so it's far enough that paying the shipping is sometimes worth it. Unless I have a large order! I see some kits with what appears to be #8 bolts vs #5. I find comfort in using #8s, but maybe it's a zinc coating?
Old Nov 17, 2016 | 02:37 PM
Alan 71's Avatar
Alan 71
Hi n,
I believe you'll find the original body mount bolts were grade #5 (3 slashes) and were zinc plated.
Regards,
Alan
Old Nov 17, 2016 | 04:06 PM
crf311's Avatar
crf311
I have a set of Rubber body mounts if your interested.
Old Nov 17, 2016 | 06:46 PM
DUB's Avatar
DUB
I myself would install rubber mounts like the facotry did. And if the kit comes with grade 5 bolts...I would use it because going to grade 8 is really not changing 'things'.
Because when was the last time you saw a photo of a Corvette coming apart due to the body bolts failing. And it is not like you are going to need to torque them past what GM did (45 lbs/ft).
Hopefully you find what makes you happy and they work for you.
DUB
To Body Mount Kit - Recommendation
