Since I completed the door ajar light project, now it is time to attack the next issue, the interior courtesy lights. The driver side door open activates all three interior lights. The passenger door does not activate any interior lights. I have a new switch for the passenger door.
Referring to page 295 (AIM), the passenger door switch shows a single wire (white). The other terminal of the switch is open. Power is routed via the fuse panel through a “16 OR” wire. With the switch in the “door open” position (contact closed), I see no path to ground. So I grounded the white wire to frame ground to see if the interior lights would illuminate, but no joy. What am I missing in interpreting this problem?
Hi Tom,
Happy Thanksgiving to you and your family..
On my 71 the only wire to the right side hinge pillar switch is a single white….as you describe.
The driver's side switch has both a light blue wire and a black ground wire.
I just told you pretty much all I know about the courtesy light circuit!
VERY dumb dealing with things electrical!
Regards,
Alan
Hi Tom,
Regards,
Alan
Yes, that is how my switches are wired. Can't figure out how the passenger side switch when in the "door open" position completes the circuit to ground? It also looks like the single white wire from the switch splices somewhere into the courtesy light circuit. Not obvious where that splice may be located.
Btw…Happy Thanksgiving!
Regards,
Tom
You're not missing anything in your interpretation but the connection at the other end of that white wire may well be missing.
The lamps in the courtesy lighting circuit have +12V at all times. The door switches themselves give the path to ground via the metal pillar. Grounding the white wire should cause them to light. You need to trace it to its other end then make sure it has both continuity (is unbroken) and has a good connection.
I also suspect the white wire is broken. When I placed the switch end of the wire to frame ground no courtesy lights illuminated. I know I am dealing with an original wiring harness so its likely it is a broken wire. I'm thinking I would just splice into the passenger side courtesy light white wire. I think electrically it would be equivalent...but there goes my NCRS judging because Alan would know!
Thanks for confirming in my mind what is probably wrong.
SM,
Are you saying that because the left side switch has a ground circuit as part of the harness, the right side switch doesn't need an additional ground because it's connected to the cage?
Regards,
Alan
The only way simply splicing into the ground wire at the nearest courtesy light could be a problem is if yours has a courtesy lamp delay. I know that a mechanical light delay circuit wasif yours an available in some earlier C3s but don't know if yours has it or how it was wired before '78 when it changed to a electronic module.
Alan & SM,
Got it! It was a broken wire (somewhere behind the depths of my panel). I disconnected the white wire from the passenger side courtesy light and touched it to frame ground and the connected lights worked. So I will splice the door light switch into the courtesy light white wire and I'll be good to go! Although I just knocked myself out of NCRS contention!
Hi Tom,
Good for you!!!
We'll be sitting down to eat in about 30 minutes and I'll feel MUCH better knowing you've gotten this straightened out!!!!!
Regards,
Alan
