I have had them on my 68 for two seasons now and just love it. I needed mostly for ride height adjustability. With a performance rubber/wheel combo and a VBP mono leaf rear it is hard to beat. Ride and handling are fantastic.
Currently running Speed Direct Coilovers with Viking Double Adjustable shocks, Van Steel 400lb springs. VBP 340lb rear monoleaf
I have the Steeroids rack and pinion for the front of my 69 right now. And, if the Sharkbite is as good as the Steeroids, it has to be good. Quality made products as far as I can see.
I have the complete Sharkbite suspension set up front and rear on my 68 convertible. The car goes to the drag strip almost every weekend. Pictures of my car can be seen in the ZIP C3 catalog under performance suspension. My handling issues were off the mark for most vets but this setup has solved more than I care to discuss for now. Talk to Daniel at ZIP and place an order. You will not be disappointed !!
