Three... two... one... lift off!
So what happened during the last 3 weeks?
I corrected the rear rotors run-out with shims. Ended up with around .0015" / .002" on both sides:
Ready to be installed:
Then mounted the new 'proportioning valve' - not a quick and easy task:
Even though I'm not going to ultimately use the old wheels, I could not see myself putting them on this shiny chassis without washing, sanding and painting them:
Then I installed the trailing arms (without the shims) and 1/2 shafts:
You can't install those struts without a lot of shim grinding:
I'm still not done with that:
Finally did a dry fit installation of the Shark Bite rear suspension.
These struts that attach to the differential cover clearly interfere with the central bracket bolt. I decided to grind the strut instead of the bolt so I can torque/remove the bolt again more easily.
I don't understand why every customer (I presume) has to go through this, instead of having the manufacturer do it in the first place:
I added primer and paint after the grinding.
Now they could fit properly:
And today, as a Saint Valentine's Day gift to my sweet '77, I finished the dry fit of the Shark Bite system
The body is getting real jealous of the chassis which has been getting all the attention:
Now I have to undo a lot of that work and redo it for good with Loctite.
Thanks for taking a peek
After the successful dry-fit, I removed the Shark Bite brackets that attach to the differential cross-member and put them back on with red Loctite.
Added the stainless steel shims at the front end of the control arms and the parking brake cable:
Installed the struts with the customized bolts:
(I still have some anti-seize to clean up)
Then it was the rear sway bar's turn:
...and finally the Wilwood D8 calipers:
I still have to add blue Loctite to a few bolts and torque them to spec.
I also bought ethanol-safe gas hoses and connected them to the gas sending unit:
What else? I took out the guts of the passenger door and refurbished them:
Yet another exciting highlight for me: I replaced my dinky cardboard toolboxes with something a bit less laughable
More pictures under February 2015 and March 2015.
Sorry for my minimalist commentary. I am a man of few words.
r
I started to work on the driver door.
Took out the greasy guts:
I was wondering why my driver window would sometimes make a loud BANG! when moving it up or down. I may have discovered why:
The power window regulator mount bracket was broken off
Luckily Willcox sells the part for $19:
Power Window Regulator Mount Bracket
The body was jealous and wanted some attention - I think it will get a lot of it in the next couple of years:
On my side I continued to refurbish parts of the driver door. The power window regulator had three problems:
#1: A broken mount bracket
#2: Worn teeth
#3: A roller with a flat spot
So I'll get a new one from Willcox.
Here are some finished parts:
#2: Worn teeth
r
). No exciting news to share. I started to shift my attention to the body:
removed the battery cables & clips, the starter solenoid relay, various harness clips in the engine compartment, water diverters.
A bit scratched up but re-usable:
Can these scratches be removed by the way?
Battery cable clips:
Whatever clip:
Vacuum hoses clips:
I also started to clean up the #2 body mount pockets:
Driver side before:
Driver side after:
Passenger side:
And finally started to scrape the passenger steel floor board:
That's all folks. Thanks for taking a peek
I have been continuing a bit the prep'ing of the floors. It'll be a while before they're ready for an epoxy primer.
I also plugged all the holes inside and out so I could pressure wash the outside without getting water inside the cabin:
There, ready for a bath, with a bath cap:
Phase 1 was pressure washing:
Phase 2 was scrubbing with scotch-brite & simple green:
It was so much fun!
Too bad it only needs to be done once.
I didn't get all the grease off. I'll continue the cleaning with lacquer thinner.
Thanks for taking a peek.
It was so much fun!
Carry on!
r
Greasy, me? That's my normal look SBG. Are you insinuating that I should be taking a bath too?
The experience was so enjoyable that I had a big smile on my face while scrubbing underneath the body.
I'm all better now and back in business.I cleaned the underbody with lacquer thinner. Took care of most of the grease and dirt. A ton of work remains though before it can be painted.
I also started to prep the firewall. Like the floor pans, it was covered with some thick coating:
After lots of scrubbing with lacquer thinner:
Barely started to get to the bare fiberglass in the rear:
Imagine my surprise one day when I stepped into the garage and a giant spider had cocooned the rolling chassis
I thought let's take advantage of this cocoon and put the body back on the chassis. I'll test out some Gulf-themed race liveries to figure out which one I prefer.
That's all for now. Have a great 4th of July!
