Three... two... one... lift off!
I'm all better now and back in business.I cleaned the underbody with lacquer thinner. Took care of most of the grease and dirt. A ton of work remains though before it can be painted.
I also started to prep the firewall. Like the floor pans, it was covered with some thick coating:
After lots of scrubbing with lacquer thinner:
Barely started to get to the bare fiberglass in the rear:
Imagine my surprise one day when I stepped into the garage and a giant spider had cocooned the rolling chassis
I thought let's take advantage of this cocoon and put the body back on the chassis. I'll test out some Gulf-themed race liveries to figure out which one I prefer.
That's all for now. Have a great 4th of July!
Thanks for taking a peek.
just a suggestion - load smaller pictures, I have windows and it's already slow as anything
Made some progress with the scrubbing of the under carpet insulation and glue. A heat gun, a scraper, automotive lacquer thinner, a brush and towels. Those have been my friends lately.
Got a FIA L88 headlights kit to inject a good dose of road racing into the project. The way I currently view the final look in my little dreamy head is:
- FIA L88 headlights.
- Le Mans gas cap.
- White side pipes.
- Sport side mirrors.
- Fender flares. 2" front and 2" rear.
- 1974 fiberglass front bumper.
- 1974 fiberglass rear bumper sans le butt crack.
- Team III's LT-III wheels. Cast finish. 18x10 front. 18x11 rear.
- 2 tone interior. Black and gray.
- A4 Corbeau black leather seats.
- Orange fire extinguisher in front of passenger seat.
- Shark bar with orange 5-point harness seat belts.
- Color scheme close to the original Gulf livery, with dark blue (not the light 3707 Zenith Blue) and 3957 Tangerine orange.
- Medium gray inner fenders, under body & under hood.
- Black chassis
Thoughts?
. Clearly look-wise, to me at least, the seamless glassing-in is way nicer. But then there's DUB's argument against it: if a bumper gets a booboo (when a bumper gets a booboo?), it's real hard to properly blend in a paint fix. To do it right you have to paint the entire front clip or rear clip.I'm leaning toward the seamless bonding. Depending on the stripes' locations, bonding becomes more or less important. I'd rather not cross a bumper seam with a stripe. Call me picky if you want.
I'm glad you're bringing this up - it's an interesting topic to me.
If someone has a 75-79 vette and wants the 73-74 front bumper look (using a new fiberglass bumper), is it easier to start with a 73-74 bumper or a 75-79 bumper? My assumption is that it's easier to just fill the top empty slot with a 73-74 than chopping & glassing a 75-79 to make it look like a 73-74. That is especially true IMO if you glass-in the bumper. Am I wrong? I may have to start a new thread to get to the bottom of this.
All the icky stuff in the rear is gone. SuperBuickGuy stopped by the other day and suggested not putting any carpet kit in the car, thus staying true to the road racer theme. I have to agree. I'll finish the interior nicely with epoxy primer + heat & noise deadener + light gray paint.
Stay tuned. Exterior progress coming next...
Here's Option #1.
Notice the stainless kitchen bowl in lieu of the Le Mans gas cap.
Cool or not cool?
Many more pictures can be seen here.
There are a few variations, including a larger meat ball on the rear, and black stripes instead of white. I tend to prefer the white ones, and you?
For the small parts, I have been using these products, plus rust removers which I forgot to include.
I typically clean them with a wire wheel or steel wool, then paint/lacquer thinner, and can paint.
Bolts/nuts also often get the rust removal & black oxide treatments, then thin coats of underhood black can paint. I will have to re-prep a bunch of them because they did not get 100% covered and started to rust.
I plan to reuse both window motors. I believe they do get weak over time but I won't get new ones unless they break down. They're pretty pricy.
SBG thinks it looks like a catfish.
Thoughts?
That's it for now. Thanks for taking a peek.
Since the last update I did my first fiberglassing: I wanted to close up some of the firewall holes since I'm doing a few conversions.
- 3sp automatic TH400 --> 5sp manual TKO600,
- OEM A/C --> Vintage Air,
- OEM padding --> Dynamat,
- vacuum headlights --> electric headlights.
So I closed up about 13 holes in total.
I started by tapering the holes on both sides. Then created cardboard disks a bit larger than the holes. Covered one side of those disks with construction aluminum tape. Used the same tape to stick them on the outer side of the firewall. That gave me flat, semi-rigid, non-sticky, surfaces to glass against from the inside. After grinding the resulting glass, I spread some Vette Panel Adhesive and sanded it smooth. The inside is now ready for a first coat of gray epoxy primer.
After that, I'll remove the taped disks on the outside and do the glassing/VPA'ing there.
One baby step every late evening.
