Dash/gauge lights not working on my 69. I don't think there is an adjustment for brightness? Guessing it's a fuse, but have not checked yet. Any ideas?
Checked fuses yesterday. The instrument lamp fuse was fine.
I am thinking I may have screwed something up previously when I was fixing my oil pressure gauge. Is there something that I could have left disconnected that would cause the problem?
All guage lights are not working. Both center console and speedo/tach lights are not working
Hi b,
There's a spade ground connection on the back of the tachometer and speedometer.
Have you checked those?
Not sure how they may have been disconnected though while working on the center gauge cluster. Has the dash been apart recently?
Is the top of the center gauge bezel cracked/broken? Sometimes that causes a ground problem.
Regards,
Alan
Hi b,
Not sure how they may have been disconnected though while working on the center gauge cluster. Has the dash been apart recently? Is the top of the center gauge bezel cracked/broken? Sometimes that causes a ground problem.
Regards,
Alan
Funny you mention that. I did crack one side of the center gauge bezel while putting the center console back together. That could be the problem?? Is that bezel part of the ground?
You can quickly verify if you have ground issue.
With the lights on:
Simply connect a long wire from any ground point (directly to the battery is easiest in our cars) and touch the other end to any metal part of the center console.
With the lights on:
Thanks for the suggestion. I checked ground between the battery and the guage cluster with an ohmmeter. All ok. Plus I tried your approach to see if the lights would come on. No luck.
I'll need to shuffle cars around to check voltage at the fuse, so I will save that for another day
Then that leaves the fuse and the potentiometer in the headlight switch.
The wire coil in the potentiometer will break leaving the only functioning setting at the full bright point. Pull the headlight switch out and rotate it to the point that the courtesy lights come on. If your dash lights come on then your POT coil is broken.
