Re-Spring or not?
Old Dec 3, 2016 | 09:01 AM
The New Guy's Avatar
The New Guy
Cruising
Default Re-Spring or not?
82 C3 CE with 84K original miles. Completely stock ,no Gymkhana. Car pancakes at 50 mph when I hit a small dip in road. Replaced rear shocks, but no change. I am getting conflicting recommendations for a fix. One side says it is the front suspension that controls ride height and I need to re do front. Other side says replace composite rear leaf. How can I tell which way to go?
Old Dec 3, 2016 | 11:08 AM
bj1k's Avatar
bj1k
Be careful if you buy new springs, get recommendations from other people that have changed their springs . Some of the rear leaf springs have too much arch and make the rear sit too high and ride more stiff . The front coils are sometimes too stiff and hard to install and might change the ride height. They are different springs for small block and big block too.
Old Dec 3, 2016 | 06:43 PM
mrichi's Avatar
mrichi
Sounds like rear spring to me
Old Dec 3, 2016 | 06:44 PM
Alan 71's Avatar
Alan 71
Hi tng,
Have you checked the ride height on your car to see what you're starting with?
Do you have the AIM for your car so you can see what the dimensions typically were for the 82 model year?
Regards,
Alan
Old Dec 4, 2016 | 05:54 PM
terry82's Avatar
terry82
on my 82 when I changed the rear shocks it helped on ride, handling and did not bottom out any more.what shocks did you put on ?
Old Dec 11, 2016 | 06:24 PM
The New Guy
Cruising
Shocks were Monroe "stock Replacement".
Old Dec 12, 2016 | 12:29 AM
terry82's Avatar
terry82
the monroes were my first choice,thinking that factory was all I need.hated them.try a pair of kyb.and a lot of guys on the forum like bilstein.
Old Dec 12, 2016 | 01:44 AM
mrichi's Avatar
mrichi
I put blistien's on made a big difference to the ride of the car
Old Dec 12, 2016 | 09:51 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Rookie here with some suggestions:
I try the least expensive repair first. You have already changed to new shocks.
As Alan said...measure the rear ride height to see how close it is to factory ride height (take tire diameter into consideration).
Can you post a pic of the rear spring to show the arch/lack of arch? That would help forum members give you better advice.
Also measure the front ride height to see if the coil springs are collapsed (take into consideration your tire diameter versus factory tire diameter).
Decide on how smooth/firm/harsh the suspension should feel to you before buying springs (I preferred a smooth ride on long trips so I bought stock coil springs and Sensa-trac shocks to fit my needs).
I also replaced all the bushings. I also adjusted the front and rear tire to fender-lip clearances to suit my tastes.
Old Dec 12, 2016 | 10:34 AM
Street Rat's Avatar
Street Rat
My '81 did the same thing when I got on it or hit a bump in the road.
I added adjustable Koni shocks and a new rear spring rated at 330.
Problem solved.
To Re-Spring or not?
