1972 intemittently dead
Old Dec 4, 2016 | 03:50 PM
endoman's Avatar
endoman
Default 1972 intemittently dead
Car starts when cold. Once driven for a while, it is totally dead when attempting to start. Only the clock works. When the key is turned, the clock goes in reverse until the key is released. Then, all of a sudden, once the horn or lights are working, the car starts fine. This is a new problem. No work has recently bee done on the car. Possible loose ground? Any ideas would help.
THANKS,
ROB
Old Dec 4, 2016 | 06:53 PM
bj1k's Avatar
bj1k
THANKS,
ROB
I have found that 90% of the time when you have a weird problem that it is a bad ground somewhere . I would start by checking connections at the battery and work your way through. Don't overlook a shorted battery.
