Alt charging
Old Dec 9, 2016 | 12:00 PM
bikemiser's Avatar
bikemiser
Default Alt charging
Why do I have to rev engine when I first started it, to get alternator to Charge? I need to add it,s an 82 C3. Once charging , it's good until it is shut off.
Thanks, Jim
Old Dec 9, 2016 | 12:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Could be a bad/dying alternator. Have you tested it?
Old Dec 9, 2016 | 03:03 PM
pws69's Avatar
pws69
Sounds like it could have been converted to a "one-wire" system - what you describe it typical behavior.
Thanks, Jim
Old Dec 10, 2016 | 12:08 AM
7T1vette's Avatar
7T1vette
Why do you think that it isn't charging? Your car has a voltmeter in it, not an ammeter. Once started and idling, what does the voltmeter read? If 13.5 volts or higher, it is likely charging just fine.
Old Dec 10, 2016 | 06:50 PM
bikemiser's Avatar
bikemiser
because when I start it, the meter shows 12 volts.
Old Dec 11, 2016 | 12:22 AM
7T1vette's Avatar
7T1vette
Yes, you have some problem with the alternator. It could be anything from a loose belt to a bad regulator module inside the alternator...or a bad diode. Suggest that you remove it at take it to an alternator shop. Taking it to an auto parts store is a losing proposition, as they will find a problem and sell you one--even if there is nothing really wrong with it. But, if you know of an honest/reliable store that knows how to check one right and will tell you the truth, great.
To Alt charging
