Random Electrical/start/light issue
I was wondering if anyone has seen something like this before.
1971 Coupe. 383 Resto-mod
On the last few drives, there has been a brief moment of what I called an "electrical stutter". She would seem like she was about to die, but then keep running, but all of the gauges and lights would flicker and the stereo would reboot.
Now it has gotten worse. Occasionally, I can open my door and none of the interior or exterior lights come on and the car will not even attempt to start. Everything appears to be completely dead as if the battery was disconnected. Most of the time, however, everything works just fine and she starts right up.
A few nights ago I went out to start her just to let her run for a while since she had been sitting for two weeks, and once again, nothing was working.
I checked the battery, ground connections from the battery, I wiggled the starter connections, grounding wire to the engine, wiggled the fuse box looking for something, but nothing worked. I sat in the front seat, not moving, not touching anything and all of a sudden the interior lights came back on and I was able to start her right up.
I didn't have my volt meter at the time, but I will use it to check voltage when it happens again.
Just wondering if anyone has seen something like this before or has recommendations for me to check.
KO
All of those things look good so far, but she's working correctly right now.
You can say I've done a few modifications.
Here is a bit of history on some of the things I've done.
https://www.corvetteforum.com/forums...a-71-pics.html
