One more tip. Ditch the gaskets on the China Wall, and use a thick bead of quality RTV instead. Sometimes the stock pieces are too tall, and wont let the port gaskets seat well. A small bead around the water ports is also good insurance.
And a good cleaning of both the block and the intake to remove any trace of oil.
Don't use the rubber seals at the two ends . They will usually squeeze out and start leaking, especially the ones without the securing nubs on the bottom. Let the sealer start setting up for about 20 minutes before installing intake to keep it from squeezing out .
