C3 body off resto questions
Old Jan 3, 2017 | 01:46 PM
kalberts's Avatar
kalberts
Default C3 body off resto questions
Hi all, thanks ahead for answers. New here to the vette so I have a "which step first" type of question. My '76 will be a track day car. Not a show car, and not an original resto. I am just about to separate the body from the chassis. The car had some front end damage, and the passenger fender, and part of the hood surround are gone. I think I will need to replace the entire hood surround, and passenger fender. The drivers fender is still intact. I guess I won't know if the frame is bent until I have the body off and can measure?? My gut tells me I should not attempt the body work until the frame is verified straight. If I were to replace the nose now, before body/chassis separation, then find the frame is bent and needs straightening, I will have alignment issues upon putting the body back on the frame. So, is the proper sequence here as follows?:
1. Separate body and chassis
2. Restore chassis
3. Strip main body (minus nose) and prime/undercoat
4. Place body on chassis
5. Do nose body work, then prime
6. Paint car
Thanks again for sharing your knowledge!
Old Jan 3, 2017 | 02:17 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: take the car to a frame shop now with body on and engine/trans installed. They can check the frame and straighten if required.
Old Jan 3, 2017 | 03:06 PM
bj1k's Avatar
bj1k
Old Jan 3, 2017 | 03:18 PM
kalberts's Avatar
kalberts
So then straighten the frame (if needed), do the body work up front, then remove it to paint the body, and restore the chassis? What if I have all the body bolts out, the motor and trans unbolted? Seems like a lot to put it back to that point.
Old Jan 4, 2017 | 11:59 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
You could just bring the frame in. They measure at points on the frame, not the body. Call your local shop and ask first. I had a buddy years ago that would explain the differences to me about frames vs unibody construction. He flipped quite a few totaled cars that had frame damage
Old Jan 4, 2017 | 12:16 PM
Easy Mike's Avatar
Easy Mike
...You could just bring the frame in...Call your local shop and ask first...
Yep. Check first. They may want engine and trans in place before they pull anything.
Old Jan 4, 2017 | 12:41 PM
ignatz's Avatar
ignatz
If you're putting in a custom exhaust, might be a good time to visit that shop as well.
To C3 body off resto questions
