Accelerator cable pictures needed.
Old Jan 24, 2017 | 06:26 AM
540 vette's Avatar
540 vette
Default Accelerator cable pictures needed.
I need a few pictures of how the accelerator cable was installed on a BB Holley. Or how you did it. My car is a 72.
Old Jan 24, 2017 | 08:23 AM
Alan 71's Avatar
Alan 71
Hi 540,
The throttle cable comes through a fitting on the firewall, is held in position by a small bracket on the left rear stud of the carburetor, and the end of the cable clips onto the carb linkage.
This is a 350/Q-Jet but the cable is the same for the Holley big block and the bracket is similar.
Regards,
Alan
Old Jan 24, 2017 | 08:37 AM
SB64's Avatar
SB64
Thank you for asking for those pictures. I hoped Alan would chime in. I am doing the same on a small block. Would you have any pictures of the gas pedal setup?
RVZIO
Old Jan 24, 2017 | 08:42 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
From photos in my collection, I believe that the accelerator cable should be routed UNDER the vacuum hoses. A'71 photo shows over. As said, using only one example for your study isn't enough......
Old Jan 24, 2017 | 11:36 AM
540 vette's Avatar
540 vette
Originally Posted by Alan 71
Hi 540,
Regards,
Alan
Thanks Alan. I just wanted to see what the bracket looked like mounted. I bought one on E Bay yesterday for a Holley.
Old Jan 24, 2017 | 03:18 PM
ddawson's Avatar
ddawson
Just a little advise. I have the same bracket for my Holley clone and it would twist sideways and actually started bending the tab.
I didn't want to tighten it with so much force as the bend the housing so I added a star washer underneath it. Now it stays in place.
Old Jan 24, 2017 | 04:32 PM
Alan 71's Avatar
Alan 71
Hi dd,
I don't know if you're referring to the bracket moving under the carb mounting nut or not.
The original q-jet bracket has a small stud that extends slightly below the bracket's underside and seats in a hole in the carb base plate. This stud prevents the bracket from moving (spinning on the nut).
Regards,
Alan
Old Jan 24, 2017 | 04:42 PM
ddawson's Avatar
ddawson
It's a little different on the Holley one.
There is a down tab at the front to fit's in a hole. You can see mine bent and I tried to fix it with the blue plastic. I ordered a new one and uses a star washer and it stays in place now.
Old Jan 24, 2017 | 04:49 PM
Alan 71's Avatar
Alan 71
Hi dd,
Ah! Ha!
Thanks!
Regards,
Alan
Old Jan 24, 2017 | 08:26 PM
540 vette's Avatar
540 vette
Thanks for the pictures guys.
Old Jan 24, 2017 | 10:37 PM
John 65's Avatar
John 65
Here's mine if it helps.
Old Jan 25, 2017 | 10:47 AM
540 vette's Avatar
540 vette
Thank you. The more the better.
Old Jan 25, 2017 | 03:29 PM
540 vette's Avatar
540 vette
O.K. lets turn it around and lets see your fuel line setup. Holley big block. The one I have needs to get a little bend in it to clear the intake bolt and the line seems to get in the way of the heater hose.
Old Jan 25, 2017 | 05:57 PM
John 65's Avatar
John 65
Here's mine, looking down from the fender it attaches to the fuel pump at the 8 o'clock position.
Old Jan 25, 2017 | 06:04 PM
ddawson's Avatar
ddawson
LS6 line on top that I cut and flared to meet the Q-jet Filter and line.
Of course you could just go all the way to the pump.
To Accelerator cable pictures needed.
