69 L89 identification
Old Feb 5, 2017 | 12:51 AM
dooboy's Avatar
dooboy
Default 69 L89 identification
Hi All, I'm looking at a 69 L89 coupe with NOM drivetrain & no documentations. How can I tell that it's a real L89 car?
Old Feb 5, 2017 | 07:24 AM
jhudec's Avatar
jhudec
There is no way to definitively tell what engine came from the factory once the original is gone. There are signs of SB vs BB, line fuel lines, diff end caps and sway bars, but nothing on the engine itself.
Old Feb 5, 2017 | 08:01 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by dooboy
...How can I tell that it's a real L89 car?...
FWIW: factory documentation with the car is about the only way to know what it might have been. Keep in mind L-89 only refers to the optional aluminum heads. You had to have the L-71 to start.
Old Feb 5, 2017 | 09:27 AM
Alan 71's Avatar
Alan 71
Hi db,
What is it about the car, or what has the seller said, that makes you think it might have been an L89 originally?
Regards,
Alan
Old Feb 5, 2017 | 09:58 AM
kenba's Avatar
kenba
From: PHOENIX AZ. WHAT A MAN WON"T SPEND TO GIVE HIS ASS A RIDE
As others have said without paperwork there is NO way to tell. Anyone can tell stories.
Old Feb 5, 2017 | 05:42 PM
63Corvette's Avatar
63Corvette
Well there IS documentation. ALL 69 Corvettes have a build sheet attached to the top of the gas tank (called the "tank sticker"). So, first I would look there. If the tank has never been dropped, it should still be there. If it is not, then ask for an explanation. Pull the rubber cuff back on the fuel filler, and shine a light under the rear deck onto the top of the gas tank to see if it is still there.
Old Feb 6, 2017 | 09:49 AM
kenba's Avatar
kenba
SEE POST #1
To 69 L89 identification
