Another wiper problem, could use some help!
Old Feb 9, 2017 | 10:53 AM
gator77's Avatar
gator77
Default Another wiper problem, could use some help!
Hey everyone, i've been searching the forums but couldn't find an answer. The wipers on my '75 stopped working. Previously they would only work on high speed. I've checked the switch and the motor with the help of Willcox Corvette's info and they both check out okay. (both are fairly new) The fuse looks good, what else can I check? Thanks in advance for your help!
Old Feb 9, 2017 | 11:38 AM
D_Williams's Avatar
D_Williams
The first thing I would do is to get some wires and connect the wiper motor directly a 12V power source and then ground the two terminals on either side of the power terminal to simulate the wiper running and switching between off/low/high. If that doesn't work then your wiper motor may be bad.
If the motor does work during this bench test then you can try running wires from the connector to the motor and see what is giving you problems.
Old Feb 9, 2017 | 11:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by gator77
...what else can I check?...
Check the wiper relay under the console.
Old Feb 10, 2017 | 10:43 AM
gator77's Avatar
gator77
Thanks Easy Mike, I was thinking that should be the next place; I'll get back with the results of that.
Old Feb 10, 2017 | 03:10 PM
Richard454's Avatar
Richard454
There's no relay used on the 73-76....
Check and make sure you put the connector on the switch the correct way- it'ill go on both ways..
Old Feb 10, 2017 | 07:09 PM
gator77's Avatar
gator77
Thanks Richard454, I've been looking for pictures of those connectors and haven't found any yet! I got the wiring diagram from papwana years ago, but that doesn't show the orientation of the connectors.
Old May 7, 2017 | 07:55 PM
gator77's Avatar
gator77
Thanks for the replies; so in case someone finds this thread in the archives, I ended up adding a separate ground wire to one of the screws that holds the switch on-solved the problem! Works on low and high speed now!
Old May 8, 2017 | 04:42 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
yep the switch needs ground for washer and high and low speed.
common problem looses ground, to the switch.
To Another wiper problem, could use some help!
