fuel pump question
Old Feb 13, 2017 | 09:50 PM
Tewski's Avatar
Tewski
Veteran: Marine Corps
St. Jude Donor '06 thru'17, '23-'26
Default fuel pump question
Is the fuel pump gravity fed from the tank? If I disconnect the "S" rubber line at the tank hardline/rubber line interface, should fuel "pour" out or just "trickle" out?
Car is a '76
Old Feb 14, 2017 | 04:50 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Whenever I open a fuel on mine the fuel pours out. T
Old Feb 14, 2017 | 07:44 AM
Alan 71's Avatar
Alan 71
Hi T,
Since the sending unit is in the top of the tank on your 76 I'd think it would be more of a trickle…. just the gas in the line.
On earlier tanks on which the sending unit is in the bottom of the tank, gravity does force the gas out the fuel line.
Regards,
Alan
Old Feb 14, 2017 | 12:53 PM
BKbroiler's Avatar
BKbroiler
On my 77 the gas pours out. Might be siphoning action, but it is much more than a trickle.
Old Feb 14, 2017 | 01:57 PM
tyrant's Avatar
tyrant
On my '69 it poured out. Made me move quick on the swap.
Old Feb 14, 2017 | 08:24 PM
Tewski's Avatar
Tewski
Hmmm, I'm getting nothing, and when I hook a vacuum pump and start to siphon, I'm only getting a trickle. Car hasn't started in 8 years, I'm trying to determine if it's the fuel pump or maybe the screen in the tank that may be clogged or the supply line. I'm not getting any fuel anywhere in the system even after I siphoned fuel to the pump and reattach the 's' tube to the supply line and the crank the engine. Nothing to the carb, filter, pump discharge, pump suction. After your post I'm leaning to a clogged screen in the tank.....
Old Feb 15, 2017 | 05:53 AM
terrys6t8roadster
I'd suspect the tank sock filter is at with fault, even though the sender is on top once the siphon action has started the fuel should just keep on coming. Mechanical fuel pumps pump, they don't have much suction to them. T
Old Feb 15, 2017 | 07:52 AM
BKbroiler's Avatar
BKbroiler
Something, like the sock or hoses at the tank must be blocked. Its a bit of a project to drop the tank. On my car the mufflers were in the way so I had to drop the exhaust system. Also, if you can't empty the tank it could be heavy, depending on the amount of gas inside. If you drop the tank, reuse the original straps to reinstall it, if they are still good. Bending new straps to fit is a pita.
Old Feb 15, 2017 | 01:15 PM
7T1vette's Avatar
7T1vette
Have you removed the vapor recovery tank? THAT is the vent for the fuel tank. If it is removed, you need to install a vented gas cap so that tank pressure can equalize.
What happens to the fuel flow (with your "S" tube test) if you remove the gas cap???
Old Feb 15, 2017 | 07:27 PM
Tewski's Avatar
Tewski
Thank you! That was it, just turned the ignition and within 2 or 3 seconds had fuel in the bowls and fired right up. Thanks everyone for your input and help!
Old May 16, 2018 | 10:35 PM
Pixsteve's Avatar
Pixsteve
4th Gear
Default 1973 vented gas cap
I’m looking for a vented gas cap for my 1973 Corvette. can I use a vented gas cap from a 68 to 69 vett. I was about to replace my fuel pump when I started going through some of your threats and realize that my tanks vent line was plugged. Because someone before me removed the vent tank up front. At the time it didn’t dawn on me I’d be creating a vacuum after I accelerated. When I put the peddle to the metal the car would die out like it was running out of gas. I thought the fuel pump was bad. Since I already replaced the fuel tank, rebuild the carburetor, blew out the fuel lines and rebuilt the carburetor, replaced all the filters. I figured the only thing left was the fuel pump. Wrong!... lol
To fuel pump question
