Looking at 68-72 vettes
I've been a reader and shopper for over a year. Gone to Carlisle 3 of the past 4 years. I've been looking in the 20-25k price range
Im looking to buy a
68-72
pref a 69 LeMans blue 350/350
4 speed
Coupe
AC is strongly preferred
Numbers matching strongly preferred
I came across a matching numbers 72 with AC
Currently red born yellow ps,pb,4speed,pw for $15k
The car has same owner for past 30 years and garage kept
The car needs paint
Has the wrong shifter (aftermarket) bubba factor low
LT-1 tach but numbers indicate a base 200hp car Vin is 1z37k2s...
What should i be looking for what is a driver like this worth as far a price range?
How do i designate close ratio to wide ratio trans?
How do I know rear gear package?
What else should i be looking for inheritance than how solid the birdcage is?
Thanks in advance for the help
Welcome!
Thinking of a 68-72 Corvette!!!
VERY nice!
I'll answer a couple of questions.
The transmission is stamped on the flange on the side of the rear case with a code indicating if it's a wide range M20, close range M21, or an M22. There's also information about when the transmission was assembled. In the same location there's also a vin derivative stamp indicating what car the transmission was first installed in.
The rear cover on the rear differential is stamped with code indicating the original ratio. There's also information about the source of the differential and when it was assembled.
This information is often considered to be part of the "numbers matching" hubbub!
Regards,
Alan
The location of the transmission stamps.
The location of the differential stamps.
Good luck.
'68s have too many "oddities"...unless you particularly want "oddities".
'70-72 have small flares at the rear of the wheel well openings which will prevent most road-rash on the side of your car. '68 & 69 do not.
'71 and later base-engine cars were engineered to run on low octane fuel (87) and they do that just fine. Performance engines work fine with today's premium fuels.
'68-71 had the light fiber-optic lamp indicators which is still neat!
'68-72 coupes had the removable rear window.
Personally, I would include the '73 car in that same group. It still has the great looking tail and chrome bumpers in the rear. But you can get most of the way to what you want for less money.
P.S. There was no 'actual' difference between '71 and '72 engines (power); they were just rated using different SAE measuring systems.
Post some pictures.
RVZIO
{I had a '68...loved it; but differences from later C3's were numerous...and odd.} [only 'finger-holds' to close doors from inside; 'blank' space on passenger dash pad; 'cigarette-pack' seat belt buckle holders...but no cup holders
; yada, yada...
I guess I got the right year car
Marshal
A solid birdcage and frame was what I was looking for. A no-hit body was next. I’ve seen a few threads here from guys that had unpleasant surprises after purchase.
Numbers matching was less important to me – and that can be a topic for debate depending on how detailed you want to get. It was important for me to know exactly what motor I had – also a topic in this forum where people have been surprised after they got it home. I think crate motors are great alternatives for drivers.
I’d say find a color you like and don’t talk yourself into settling for something thinking you'll just paint it. Unless you have the tools & skills a professional paint job is probably the single most expensive thing you will do to that car. I bought one with a paint job I could live with and intend to drive it a few years and work out all the other money-sucking issues these cars inevitably develop.
Don’t know where you live but for me A/C it wasn’t an issue – mine’s a convertible and I live in the northeast. The heater core is good, which does matter. The compressor was already out when I got the car when I got it and I later found the condenser to be a disgusting mouse house. Getting a working 134a system would be prohibitively expensive for me so I am in the process of ‘de-airing’ it. Removing all that made lots of room if I ever want headers, which I might. A/C can add cost and complication.
Mine was under $22K delivered to my front door. I do have a little buyer’s regret that I didn’t get the price lower but after looking at a lot of junk in the same price range I figured that was OK. Those years do tend to run more $$ than the later ones.
Sorry to run on. Just went through this, plus I’m stuck somewhere today for 8 hours and nothing to do…..
Hope this helps. Good luck !
Key statement. Everyone wants the best deal, but condition is everything. No hit body? 45-49 yr old car, ok good luck with that. Under $20k for a complete no hit no rust chrome bumper car with original equipment? Thats a dream come true, point me to one and I'll buy it too. Rust in my opinion is the number one deal killer. Be very careful inspecting the car. Read the sticky on what to look for when buying your first C3. You can fix mechanical stuff like brakes and leaky power steering, rotted suspension parts etc. But rust is like cancer. It just never ends.
And its been said before and I"ll say it again, buy the very best car you can afford. It takes a whole lot of money to take a worn out neglected no rust car to show level, let alone a rust bucket.
; yada, yada...
I have an '06 Z06, Lemans Blue with Charcoal interior, fully loaded. I'm the original owner and it has less then 12,000 miles.
