HI Guys, I'm in the process of removing the engine and 4 speed together from 71 LT1. I've unhooked everything to the engine but I've read conflicting info on the trans removal since I'm pulling it one piece (both need to be rebuilt). Do I need to drop the driveshaft or just disconnect it a the rear of the trans? I read I don't need to remove the shifter. If that's true, do I disconnect at the linkage or the arms? Anything else I should watch for? Thanks in advance.
2016 C3 of Year Finalist
I would tape the crap out of the tailhousing to keep the oil in it or find a piece of pvc and make a plug. That oil will get everywhere. And you dont want to slip in it and fall, taking the motor with you
I just reinstalled a 454/4 speed assembled combo into my 71 without a removable cross member.
I used a HF A-frame crane with a chain fall and engine leveler. I removed the hood and rad support and had the car lifted up about 8-10 inches after the power package was over the nose of the car. Worked much better than just the motor and bell housing together and the rad support still installed (first go around years ago before project stall). Only thing I wish I had done was leaving the freshly installed fuel pump off.
I didn't have to contend with the driveshaft or shifter (both were not installed), but it was a pain to install the shifter and brackets AFTER the trans was in the way. Wish I had thought to install the trans mount brackets and shifter before the engine/trans was in place.
No hood, no rad/rad support and a small block w/trans should be OK.
Pull the driveshaft - Mark the driveshaft and the tranny yoke with some white-out or chalk so that you put it back together in the same position/phase. Leave the yoke in the back of the transmission (that will keep the lube in) and just wire or tape it to the tail shaft to keep it from sliding out. On my '70 I remove the rear of the driveshaft 1st (you'll need to pull some bolts and swing the stability plate under the front of the rear end down and out of the way first. You can then push the shaft forward to get it out of the rear input yoke. Might need to pry it forward - large screwdriver between the yoke and U-joint to get it loose. Tape around your U-joint caps with electrical tape to keep the caps and bearings intact.
Unhook the shifter rods from the transmission as stated and leave them hang along the side out of the way. It will all pull out in one pc.
While you have the tranny out, clean it up, block it up on a bench and drain it. Good idea to replace the $6 rear seal at the tailshaft while you have it out - cheap insurance. Pry out the old one and tap in a new one. All the auto parts stores carry them.
You can pick up one of those plugs at any transmission shop and re-use it for years on future jobs. I've had one for over thirty years . They fit inside and fit snug to the rear seal . You can tilt the transmission all the way back and it will not leak.
Hi Mark,
Looks good!
Do you have something good to put it on?
There was recently a thread describing an engine that tipped over because the 'stand' wasn't as sturdy, or as well balanced as needed.
Regards,
Alan
