Interior Dye / Masking Question
Old Mar 7, 2017 | 05:00 PM
raydog9379's Avatar
raydog9379
Default Interior Dye / Masking Question
So I've been trying to dye the interior roof panels (halo ones behind your head) on my 78 SA on/off for a while now. I have the Corvette America dye in a spray can.
Here's my problem. I have an oyster interior and there is a maybe 2-3 inch black trim line on the back of them. No matter what I do, I run into 2 problems.
1) Masking tape (I've used various types of painters tape and even specialty tapes that supposedly won't lift off paint). I'll get a crisp line and then when I go to peel the tape it lifts off the dye of the other color (either black or oyster depending on what area was masked). I've let it dry for days or in some cases months with the same issues.
2) Tried using cardboard and whatnot to shield the area and get overspray bleed across.
I've also tried spraying some of the black into a container and using a brush, but I'm not getting the results I want.
Anyone have any ideas since I'm clearly not a paint expert? I'm almost at the point where I say screw it and buy a new set, but I'd rather not spend over $200 on an issue that should cost me next to nothing at this point. I can spent it elsewhere on the car for sure.
Old Mar 7, 2017 | 05:39 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
peel the tape when the paint is still wet or tacky. or wait until it drys and carefully run a sharp razor blade along the tape line
Old Mar 7, 2017 | 06:49 PM
dennis's Avatar
dennis
Prep is the key. Make sure everything is clean and prepped for the interior paint. Try using frog tape yellow(very low tack). I would also leave it be for a few days before removing the tape.
Old Mar 7, 2017 | 08:40 PM
SPCL FX's Avatar
SPCL FX
Try using an adhesion promoter like Bulldog ! After everything is clean and dry all you do is spray it ( comes in a can as well ) make sure that you clean with wax and grease remover ,let dry , spray lite coat of Bulldog , let dry , spray color , tape , spray color again ! Hope this helps , I do custom paint for a living!
Old Mar 7, 2017 | 09:57 PM
croaker's Avatar
croaker
Not to hijack but, soft items like cushions no bulldog ?
Old Mar 7, 2017 | 10:39 PM
raydog9379's Avatar
raydog9379
No worries... we're all here to learn and make our cars better
Old Mar 7, 2017 | 10:45 PM
raydog9379's Avatar
raydog9379
Adhesion promoter or lack of is likely my issue on why it just lifts with the tape. I even bought ultra low tack tape and it lifted. I'll grab a can of bulldog and give it a shot.
One other question for you guys... on the areas where it lifted from tape, do I build up layers to fix that or use superfine sandpaper and knock the edges to blend it or acetone on a cotton ball (or is acetone not worth the risk)? I also want to make sure I don't lose the fake leather graining in the piece if at all possible.
Thanks!
Old Mar 8, 2017 | 10:03 AM
SPCL FX's Avatar
SPCL FX
Thanks!
If your not comfortable with using Bulldog there is another way you try ! You said that you were getting overspray using cardboard , so instead of cardboard try using and old car tag ! You'll need to tape off the mount holes and do a little at a time ! It will help to have someone else hold the tag while you spray ! Also try using cue tips instead of cotton ***** which will give better control during clean up ! Still you need to be extra careful and not let it be wet for too long ( wiping without dry time ! Again be extra careful and don't rush ! Hope all this helps ! Your paint supply stores are always willing to answer questions and you can carry your piece in and get first hand help !!
Old Mar 9, 2017 | 09:09 PM
bazza77's Avatar
bazza77
a lot of effort but it is worth it in the end
To Interior Dye / Masking Question
