Is this negative electrical draw normal?
Old Mar 11, 2017 | 08:01 AM
Tom69's Avatar
Tom69
2018 C3 of Year Finalist
Default Is this negative electrical draw normal?
I purchased this car with the windshield wipers inop. I replaced the wiper motor so the system is now operational. The other day I drove the car in the rain with the wipers, headlights, and AC on. My ammeter showed about a needle width negative draw. Would this slight discharge be considered as normal for this vintage car?
Regards,
Tom
Old Mar 11, 2017 | 08:20 AM
Alan 71's Avatar
Alan 71
Hi Tom,
No.
The ammeter indicates the rate at which the battery is being charged.
A discharge indicates that the electrical demand is more than the alternator's output.
You can test the alternator's output.
Regards,
Alan
Old Mar 11, 2017 | 08:57 AM
Tom69's Avatar
Tom69
Originally Posted by Alan 71
Hi Tom,
No.
Regards,
Alan
I guess the first thing to check when I get back in town will be alternator belt tension.
Thanks,
Tom
Old Mar 11, 2017 | 10:21 AM
bj1k's Avatar
bj1k
Thanks,
Tom
Yes check the belt first might just need tightened but as Alan said have the alternator checked . It could just be that the gauge is off a little being an old car but start with knowing that the alternator is charging properly .
Old Mar 11, 2017 | 10:55 AM
Alan 71's Avatar
Alan 71
Hi Tom,
Didn't ask the obvious question…. does the needle progressively move toward the + side as you turn off the electrical accessories?
Regards,
Alan
Old Mar 11, 2017 | 11:16 AM
Tom69's Avatar
Tom69
Hi Tom,
Regards,
Alan
Yes.
Old Mar 12, 2017 | 12:35 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
yes its normal. Its the draw of amps on the system, each item should show more draw, opposite as you turn them off, A volt meter wouldn't show much deflection because its how many volts are being produced. Each meter has its pluses and minuses.
To Is this negative electrical draw normal?
