Headlight adjustment
Old Mar 31, 2017 | 12:39 PM
Dave Vincec's Avatar
Dave Vincec
Default Headlight adjustment
Hi guys,
Just got my project back after a little trip to get a new seatbelt anchor welded in, and now trying to get last bits done so I can ship it out to get painted..
Newly installed vacuum systems are functional, but the headlights seem to overextend and lock out.. when you turn them off, you need to put your hand in and unlock the mechanism, after which it closes to plan.. then opens again when you pull the switch.
I am assuming that the mechanism to stop this lockout it the adjustment screw on the leg that hangs down?
If so, have I misassembled it, as the screw on one side just touches the housing as it locks, and on the other side it doesnt even make contact!
Many thanks for thoughts?
Old Mar 31, 2017 | 12:40 PM
Dave Vincec
Old Mar 31, 2017 | 06:12 PM
bazza77's Avatar
bazza77
If it doesn't pull it down ,then you have a leak on that side of the vac system . could be just a worn hose end .
I removed the other "advice" as I had it wrong , sorry
Old Mar 31, 2017 | 06:42 PM
theandies's Avatar
theandies
The AIM has the proper way to adjust the headlight doors.
Old Mar 31, 2017 | 07:10 PM
Alan 71's Avatar
Alan 71
Hi,
I believe you need to be careful using the 'stop' bolt to adjust how far the door opens.
I believe the clevis is to be used to adjust the open position.
I think the long arm and 'stop' bolt was intended to aid in preventing the headlights from vibrating while driving.
The AIM notes that the clevis must be set first and then the 'stop' can be set.
Regards,
Alan
To Headlight adjustment
