c3 water pump question
Old Apr 7, 2017 | 07:36 PM
rj911's Avatar
rj911
Cruising
Default c3 water pump question
I have a 73 sbc, when i took the engine in for rebuild, it was complete with the fan and pullies intact. The engine builder tore everything down and said the water pump was bad, i purchased a new short water pump for it, but now when i attempt to put the fan pulley on, it hits the pump. I dont know it there was any spacers behind the pump, the builder says there wasnt. It is the same pulley that came off the engine. I bought a second short style water pump, same problem. Does anyone know if there are supposed to be soacers behind the pulley ? The pump measures 5-5/8 from mount face to impeller face where the pulley mounts. According to my research, this is correct.
Old Apr 7, 2017 | 08:08 PM
MISTERZ06's Avatar
MISTERZ06
not sure hope this helps
http://www.zip-corvette.com/68-82-c3...mp-pulley.html
https://www.summitracing.com/experta...ive/answer/913
........................................ tom
Old Apr 7, 2017 | 08:18 PM
rj911's Avatar
rj911
Cruising
Thanks, I checked it out, its pretty much what I had already known. Im just stumped as to why my pulley that came off now doesnt fit the water pump, it hits the pump before its seated on the impeller shaft. It IS a short pump, measures 5-5/8. Its kind of making me crazy. I dont want to just keep buying pumps until one works, its time consuming and a pain to have to return them. Who would have thought that something as simple as a water pump and pulley would be the challenge after doing a frame off !
Old Apr 7, 2017 | 08:22 PM
MISTERZ06's Avatar
MISTERZ06
seems like it is the wrong pulley
http://www.zip-corvette.com/68-82-c3...ey-spacer.html
http://www.ecklerscorvette.com/corve...1971-1982.html
........................................ ........ tom
Old Apr 7, 2017 | 08:59 PM
MISTERZ06's Avatar
MISTERZ06
1972 350ci/200hp 4spd, power steering, no AC, no smog pump
short water pump
Old Apr 8, 2017 | 12:03 AM
7T1vette's Avatar
7T1vette
Tell the engine builder to figure it out "on his dime". He's the one who said the pump was bad (how the heck he knows that, IDK); he should have spec'd a proper replacement for what you GAVE HIM in the first place.
Old Apr 8, 2017 | 01:20 AM
rcread's Avatar
rcread
How much more space do you need? When I replaced my water pump I had to grind a bit of material away on the new one. It lasted 18 years until I replaced it with a reverse rotation because of the serpentine belt system on the new engine.
Old Apr 8, 2017 | 01:41 AM
thb72's Avatar
thb72
The pulley is fine. A corvette pump is different than a standard short pump. it should have a 3/4 shaft and the impeller face should be about 3/16 farther from the block. Research the archive on the forum the information is there.
Old Apr 8, 2017 | 12:11 PM
MelWff's Avatar
MelWff
How about posting the manufacturer and part number of the pump inorder to determine if you have the wrong pump
Old Apr 8, 2017 | 12:19 PM
540 vette's Avatar
540 vette
Why all of a sudden it would be the wrong pulley. It worked before he changed the water pump. Just wondering.
Old Apr 9, 2017 | 07:42 AM
Cool95vette's Avatar
Cool95vette
How is it lined up with the other pulleys? Does it look like it needs to go on fully to line up with them?
Old Apr 9, 2017 | 10:15 AM
Peterbuilt's Avatar
Peterbuilt
You need a Corvette specific water pump, here are the dimensions.
Old Apr 9, 2017 | 10:25 AM
Big2Bird's Avatar
Big2Bird
No spacers when stock. But Moroso does make shims to correct pulley/belt alignment.
A friend had a 454 that ate belts. I realigned all the pulleys with shims, and no more issues.
Old Apr 9, 2017 | 10:44 AM
Dynra Rockets's Avatar
Dynra Rockets
I had a similar problem when I purchased an aftermarket aluminum pump. I clearanced the pump body about .030" with a dremel and added a small shim to the backside of the stock pulley. No biggie.
Old Apr 10, 2017 | 10:35 AM
MISTERZ06's Avatar
MISTERZ06
i looked at my original water pump on my 1972, 350/200hp, power steering, no smog
AND the pump had a space ground (from the factory) down at the very top where the pulley is
the ground/machined is right in front of that square plug
and the clearance from the top of the pulley to the water pump is very very small
sorry i did not take pics ................. tom
To c3 water pump question
