Newbie Motor Question
Old Apr 10, 2017 | 03:16 PM
lsintampa's Avatar
lsintampa
Default Newbie Motor Question
Greetings - new member here...
I just bought my first C3, a 1975 coupe. (today)
I'm just now trying to hunt down the engine number. I've looked everywhere, no luck yet.
The PO did state that he thought the motor was not original.... and I really don't care, except I would like to know what motor we have.
The only CLEAR stamping I can find is GM 42 on the left rear of the motor.
There is another number just a bit lower, but it is so hard to make out. Hey, I'm 66 and the eyes are about shot.
Anyway, any insights as to what I have or where else I can look, would be appreciated.
No numbers can be found on right side at all.
Pics of the car and best shot I can get of the motor....
I'm sure I'll be asking a ton of questions along the way.
This is my 2nd corvette, had a 69 way back when I was like in my early 30's.... it was a basket case.
The 75 has very good bones... body mounts are great, car runs good, most curious about that motor though.
Thanks,
Len
Old Apr 10, 2017 | 03:25 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The pad is on the block at the front of the passenger's side head.
Old Apr 10, 2017 | 03:38 PM
JoeMinnesota's Avatar
JoeMinnesota
Sharp looking ride! Also check for the casting number on TOP of the rear end of the block on the drivers side, behind the valve cover/cylinder head.
As Mike says, pad is on the passenger side front of block, in FRONT of the head. Flat, narrow pad on top of the block and you may need to wipe with a rag and some cleaner to make out the stamping if it's still there.
Old Apr 10, 2017 | 03:43 PM
JoeMinnesota
Here's some help. Once you have numbers we can help decipher.
Old Apr 10, 2017 | 04:52 PM
lsintampa's Avatar
lsintampa
Default Found it, I think
OK, the front PASS side stamp photo attached... it was painted over...
Photo of motor compartment as well.
Doesn't appear to be a matching motor based on VIN of the car...
That aside, I'm praying for some good news here.
Thanks,
Len
Old Apr 10, 2017 | 04:57 PM
Revi's Avatar
Revi
Your block casting number looks like 14010287, 1980-82, 350, 2-bolt Passenger. The blue paint is also a giveaway for post 1977.
CEU 1980 350 - L LM1 190hp - Camaro
Old Apr 10, 2017 | 05:02 PM
lsintampa's Avatar
lsintampa
I think it is a 1980 Camaro motor... 190 HP
So the 75 350 vette was 165 ...
Anyway, not worried about the HP rating, but I do wonder what it does to the value of the car.
Given the car is CUSTOM anyway, does the later motor help or hinder the cars value???
Old Apr 10, 2017 | 05:14 PM
Alan 71's Avatar
Alan 71
Hi Len,
Welcome!
First posts!
New Corvette TODAY!!!!
You must be VERY excited!
I hope it turns out to be a real pleasure for you!
Good Luck!
Regards,
Alan
Custom?
Old Apr 10, 2017 | 06:25 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
More engine ID pad location information can be found by clicking...
here.
Welcome to the Forum!
Old Apr 10, 2017 | 08:56 PM
dprinter1's Avatar
dprinter1
Hey Len,
Welcome to the forum....Nice ride, Gotta love those C3s, hope all goes well with it
Old Apr 10, 2017 | 09:17 PM
bj1k's Avatar
bj1k
I don't think I've ever seen the numbers stacked like that . They are usually side by side and they don't look like GM stamps were used so looks like a re-stamp . But for what reason ? Nobody would try to pass it off as legit even if the numbers did match. As someone mentioned it does look like a post 70's engine or they used a post 70 intake according to all of the sensors and vacuum ports on the water inlet . I'm not familiar with the 75 if it had those . But it is always fun to track it down and see what you have and if it is not what you want it will be a good excuse to buy a performance crate engine.
Old Apr 11, 2017 | 07:55 AM
Revi's Avatar
Revi
The shape and size of the engine pad changed post 1977 (not sure which year?), that's why the numbers are stacked.
To Newbie Motor Question
