Shifter Console Extension Trim
Old Apr 12, 2017 | 12:46 PM
JohnnieUtah's Avatar
JohnnieUtah
Default Shifter Console Extension Trim
Does anybody use these? I see a lot of images of people's interior and rarely see this trim installed. For as little as they are they sure are expensive...$50 each! Love to hear from you all.
Old Apr 12, 2017 | 01:25 PM
Alan 71's Avatar
Alan 71
Hi JU,
Those shifter console extensions were original installed on a/c convertibles (and 'maybe' some coupes with a/c) to help hide the additional cowl braces that convertibles had.
Regards
Alan
Old Apr 12, 2017 | 01:31 PM
JohnnieUtah
That's good to know. Thanks!
Old Apr 12, 2017 | 01:33 PM
JC68's Avatar
JC68
Johnnie
You don't see many because they were only used on convertibles with certain options.
The extensions were used on all 1969 convertibles that used the early style under dash bracing. It covered up the lower brace that was otherwise visible. When the under dash bracing was revised during the 69 model year the extension was no longer required on non-AC cars and it was dropped.
Convertibles with AC continued to use a version of the older style bracing and still received the extension until the end of production in 75.
Late 68 convertibles also used the same bracing system as early 69 with the lower brace visible, but they did not use the extension to cover it up.
John
To Shifter Console Extension Trim
