1977 Trim Plate
Received 2,878 Likes
Hi b,
During the 68-72+ (?) period the trim plate was placed on the hinge pillar after the body was painted, so it typically was unpainted.
If some paint touch-up was done further down the production line a plate might have a bit of incidental overspray on it, but that would be a rare case.
Regards,
Alan
Regards,
Alan
From the NCRS 1975-77 Tech & Judging Guide: " It is attached to the driver's door hinge pillar by two aluminum pop rivets between the first and second color coats. As a result some paint should be on the plate and rivets." "In general, most 1975 plates are well covered with body color paint. Later years are usually less well so." Earlier tags such as '70-72 should not have paint on them.
bj61662 (04-25-2017)
If you find a conflict with the two posts above...they are both correct but for different periods of St Louis plant production. Around 1975-76, the plant restructured space and the booth where trim tags and VIN plates were attached. Prior to this period, tags were placed after paint, as Alan indicates. Somewhere in the 1975-76 period, the booth was moved to a location between the two paint booths to make space for increased plant production. Tags were thus attached at this point.
As a result, the stainless steel trim plates were not primed but covered by the second paint coat as ragtop states. Clearly by 1977, those plates were painted with one coat and it's not unusual to see trim tags where the paint has flaked off. I interviewed a Bowling Green plant engineer who had been a St Louis plant supervisor and explained the change to me
jbh06751 (07-10-2018)
Received 2,687 Likes
I like mine polished.
Thanks to expert
On 75-81 cars where the paint has been removed from, or has peeled off of the trim tag, there will usually still be signs of paint inside the hole in the trim tag rivets.
Bikespace (10-08-2017)
Thanks for that! I checked both my cars, '79 and '80, and although the trim tags are shiny (one more so than the other), both have indications of the correct paint in the pits of the aluminum rivets. Both cars have been repainted, in the correct original color.
bj61662 (01-14-2018)
