1973 Corvette
Old Apr 24, 2017 | 02:15 PM
desmo136's Avatar
desmo136
2nd Gear
Default 1973 Corvette
What should I look for when buying one?
Thank you, Brian
Old Apr 24, 2017 | 02:23 PM
henrikse's Avatar
henrikse
Well where to start. Of course make sure the birdcage is OK. Lots of writeups on site but check for rust as this is where it goes.You can pull the kick panels and look at the mounts to see rust and up as well as inspection plates in rear wheel well. Look at frame for obvious signs of rusting. See if the lights go up and down. Check wipers, heater controls as they are all vacuum and troublesome. If you can see up behind lights there is a metal plate right across where hood joint is that also is a rust spot.
Then overall body condition making sure the door and hood gaps are equal. Weatherstripping usuall will cause water to leak inside so check all of it.
Then the motor and trans. You can check serial # and engine and trans #'s if you are looking for numbers matching. Does it run and shift.
Probably lots more but a start. Ensure all parts are there because costly to replace.
Old Apr 24, 2017 | 02:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by desmo136
...What should I look for when buying one?...
https://www.corvetteforum.com/forums...-corvette.html
Old Apr 24, 2017 | 04:11 PM
Alan 71's Avatar
Alan 71
Hi Brian,
WELCOME!
And thinking about an old Corvette! Good!
You really need to describe, even generally, what type of car you're looking for.
For instance an original car or a modified car?
A coupe or a convertible?
A big block motor or a small block.
Something that's ready to drive or one that will take a little, or a lot, of work?
How will you use it?
Will you be maintaining it or will someone else?
BUDGET!?
Then besides giving you an idea what to be looking for in general (no rust, completeness, condition, etc., folks can give you some ideas of specific things to be on the look out for.
So, what are you thinking?
Regards,
Alan
Old Apr 24, 2017 | 10:48 PM
mardyn's Avatar
mardyn
For sure read the sticky at the top of the page about 10 rules.... I didn't and it cost me $$ and time to bring the car I purchased up to a decent standard. After two years of searching, I got impatient and bought one that I thought was "close enough"... and while I'm pretty happy with my 73 now, I've kicked myself numerous times over to he past three years for losing my patience and buying something other than I really wanted in the first place. Good luck. mardyn
Old Apr 24, 2017 | 11:00 PM
jr73's Avatar
jr73
Desmo all I can say is you are looking into the best year Vette, good for you man
To 1973 Corvette
