Better visibility for side mirrors?
Old Apr 24, 2017 | 08:20 PM
drmonstaa's Avatar
drmonstaa
Default Better visibility for side mirrors?
So after a year of letting my vette collect dust due to school, I finally got back to working on it.
One of the issues that had to be addressed was the really bad visibility of the sport mirrors on the '76. It must be more of an issue for short people like me as i only found threads asking how to convert from chromes to sport... (why do i have to be 5'5" )
That being said, i shall inquire about the opposite, how much better is the visibility of chrome mirrors vs sport mirrors, and is it worth it to switch? How about sticking on convex mirrors?
thanks in advance
Old Apr 24, 2017 | 10:43 PM
gbvette62's Avatar
gbvette62
The 75-79 so called "large head" mirrors, will give slightly better rearward visibility. They stand up a little bit taller, and have quite a bit more mirror surface. Even so, the rear fender bulges still dominate the view, when using the mirrors.
Old Apr 24, 2017 | 10:55 PM
79C3tnd's Avatar
79C3tnd
Try adjusting your mirrors as suggested in the article below. Have an open mind. Then get out on a highway and try it out. Simply amazing! I was skeptical at first, but after driving with my mirrors this way for a few years, I have no idea how I used to drive the "old" way. Your 'humps" won't be filling up your mirrors if they are properly adjusted...
http://www.caranddriver.com/features/how-to-adjust-your-mirrors-to-avoid-blind-spots
Old Apr 24, 2017 | 11:05 PM
theandies's Avatar
theandies
http://www.caranddriver.com/features...id-blind-spots
I agree, if you can see the side of your car in the mirror it's not properly adjusted. Next time your sitting at a light with cars next to you (in any car you own) adjust the right mirror (or left if there are cars to that side) so you can see the car to the right and behind you. When you see that car in your mirror your mirror is adjusted correctly.
Old Apr 25, 2017 | 12:24 AM
72downunder's Avatar
72downunder
Totally. any driver training course will tell you the same. Thats how I have my mirror and I'm a left drive in a driving on the lefthand side of the road country.
Old Apr 25, 2017 | 08:00 AM
Alan 71's Avatar
Alan 71
Hi II,
The 68-74 mirror is designed in an interesting way… the 'stalk' doesn't mount to the center of the mirror…. it's off-set.
This off-set allows the mirror to pivot 360 degrees which varies how high/low it is and also how close/far from the door it is.
Might this degree of adjustment be of some help to you?
Regards,
Alan
Old Apr 25, 2017 | 03:04 PM
drmonstaa's Avatar
drmonstaa
Thank you all for your inputs, i think i'll try the mirror config in that link, and if that doesn't work out i'll go to the chromes.
Old Apr 25, 2017 | 04:04 PM
theandies's Avatar
theandies
Originally Posted by Alan 71
Hi II,
Regards,
Alan
Also notice the "small" side of the up/down offset is at the bottom. Even though the mirror can be rotated 360 degrees the "small" side should be down. This raises up the mirror. I've seen some pictures of member's cars that have it up-side-down. If it's up-side-down it will be too low and all you'll see is the rear fender hump.
Old Apr 26, 2017 | 05:49 PM
army's Avatar
army
What about getting a backup camera? I'm thinking about it myself. I really like the cam in my wife's Edge.
Old Apr 26, 2017 | 06:13 PM
theandies's Avatar
theandies
Ya, my wife's Explorer has one. It's nice but to be honest I forget it's even there most of the time. Call me old school.
Do you plan on keeping it on all the time? Also backup cams don't really show you the blind spot.
Old Apr 26, 2017 | 11:18 PM
Robert Thomas's Avatar
Robert Thomas
Army Hoist Operator
The side view mirrors in my '78 only let me know that the rear fenders are still attached. The inside mirrors verifies the retention of the roll bar and the rear spoiler. I bought a backup camera and 5" monitor from Amazon for $30. The camera is mounted on the back of the roll bar and since it's wide-angle the rear vision is very good.
Old Apr 26, 2017 | 11:28 PM
Scottd's Avatar
Scottd
How about you turn your neck and look?
Momma taught me to check the mirrors first....look over my shoulder....mirrors again.....then move.
I do this in my Corvette, my motorcycle and in 10 Ton armored vehicles.
Adjust the mirrors.....but ALWAYS look. Mom was never wrong.
Old Apr 27, 2017 | 12:32 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Several years ago I approached a company (I forget the name) which once made a high quality stick-on driver's side convex mirror for the C4 about doing a run for the "big" C3 sports. Unfortunately, they weren't interested enough to even site how many would be necessary for a minimum order. If anyone might know of a source offering that fitment today, please fill me in.
However...
Old Apr 27, 2017 | 09:10 AM
army's Avatar
army
I have a bunch of antique tractors and golf carts and a bone stock flathead V8 `50 Ford F47 pickup so I'm somewhat old school myself. I'd like a backup cam for the truck too but I don't see them as a replacement for side mirrors. More like an extra point of view. I'd leave it on all the time not just when I'm in reverse.
To Better visibility for side mirrors?
