Hi G,
The light was a part of all 68-72 cars.
Regards,
Alan
This is the typical configuration. Your car appears to be missing the hole for the light and switch in the compartment farme, and the shield and plastic lens that's part of the compartment flocked liner.
Hi G,
Regards,
Alan
Hi Alan,
Thanks, the compartment was likely replaced somewhere in the past then, but the wiring should be present if I understand correctly?
I'll check it when I get the chance to do so.
