Lower "V" ignition shield.....?
I picked these up for $16 because they were a little rusty....I cleaned them up with some aluminum foil and Prep & Etch.
Before....
After....
Brian
M-5 if I remember correctly x12mm
I actually took me longer to replace all the wires and shielda and dist cap rotor and cover...than it took me to pull the transmission!
Next time I do this job....Im going to get the Big-block shielded wires and #$%^ -it!
Thanks for reminding me of the 150 boo-boos from ripping my arms to death getting all that shizzle out and back in!
Some people find it easier to run the 4 forward wires by starting at the spark plug... which allows you to run the small distributor cap boot through the engine mount rather than the bulkier spark plug boot.
Regards,
Alan
2. Ensure that they are not crossed, because you can't un-cross them.
3. Lube up the motor mount and boots with SILICONE (liquid) and the slip in with a little 'poking'
4. Over engine/under engine/over engine/under engine...rinse and repeat 50 times!
I see someone has said you must remove the starter...While I can't definitively say that is untrue as far as big-blocks go...it IS UNTRUE for small blocks....I'm not saying its easy....I bled a bucket...but I did not have to remove the starter.
I did on the 82 have to remove the temp send unit and shroud.
The 69 350/350 was a lot easier!
Like I said, next time...I'm going to get shielded wires and run them where I want. ABSOLUTELY HUGE @$$ Pain.
We have to remember that the factory did this monumental task while the engine was not encapsulated by the body....in that case it's a 15 minute job!
My wires are already ran thru the mounts so that part of the job won't be an issue.
Brian
I really don't recall the starter being that big of an issue, but I'm not doubting you. I'll try to crawl under there this weekend to see if I can remember how I did it
Zora had a headache that day!
