Accelerator Cable Fix - Neat Trick
Old May 9, 2017 | 11:29 PM
JohnnieUtah's Avatar
JohnnieUtah
Default Accelerator Cable Fix - Neat Trick
Just thought I would share this neat way to change the pull on your accelerator cable. While searching the forum some folks have used a zip tie. But I think this is even better. Just grab your fishing tackle box and grab a 1/4" diameter split shot. Drill on center a .065-.070 hole with a slight opening on the slit. Spread it, compress it and that's it. This works so nicely.
Old May 10, 2017 | 07:25 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Did you do this cause the was slack when you depressed the pedal , I was looking at my pedal when I did the carpets and noticed some play there. Great Idea.
Old May 10, 2017 | 07:42 AM
JohnnieUtah
Yes. When the cable was pulled forward all the way it was ahead of the ball stud on the carb about a half inch or a little more. Adding this one split shot solved everything and only put it about an 1/8" ahead. Now my secondaries are fully open and I still have allowance for my sound deadener and new carpet
Old May 10, 2017 | 12:32 PM
TimAT's Avatar
TimAT
Be careful that you don't over travel the throttle at the carb. It could stick over center.
Old May 10, 2017 | 12:47 PM
JohnnieUtah
Very doubtful that could happen due to the stop tang on the throttle linkage. When the secondaries are fully open your stop tang is engaged and that puppy is pretty stout.
Old May 10, 2017 | 03:03 PM
Richard Daugird's Avatar
Richard Daugird
Good for three tenths.
Old May 10, 2017 | 07:25 PM
TimAT's Avatar
TimAT
Good enough. I'll disregard the instructions that came with my carb,,
To Accelerator Cable Fix - Neat Trick
