Disconnecting parking brake cable
Old May 11, 2017 | 08:48 PM
Tewski's Avatar
Tewski
Veteran: Marine Corps
St. Jude Donor '06 thru'17, '23-'26
Default Disconnecting parking brake cable
I am preparing to remove the body from the chassis and I need to disconnect the parking brake cable, is there a preferred location to do this? i.e. at the handle? Spring/threaded rod? Other? I'm just want to minimize any adjustment problems down the road. The car is a 72.
Old May 11, 2017 | 10:33 PM
sullyman56's Avatar
sullyman56
I would loosen the cable at the spring/ threaded rod and remove it at the handle.
Old May 12, 2017 | 07:36 AM
Alan 71's Avatar
Alan 71
Hi T,
I agree with s56.
It's one of those things I'd be taking a photo of before I disconnected it.
Unless the the parking brake isn't restored, and the body gets back on the frame in EXACTLY the same position…. the brake will need to be readjusted.
Regards,
Alan
To Disconnecting parking brake cable
