Missing Bolt
Old May 17, 2017 | 07:30 PM
Sig1977's Avatar
Sig1977
Default Missing Bolt
Does anyone know the length of the bolt you remove to access the fuel pump pushrod to keep it in place when replacing a fuel pump. I know the bolt is a 3/8 x 16 I just don't know the length. Mine is missing. Application Small block 350 L82 / 1977.
Old May 17, 2017 | 07:48 PM
sparky77's Avatar
sparky77
Just did mine it was a 3/8 X16 X 1/2 long bolt .
Old May 17, 2017 | 09:47 PM
Sig1977's Avatar
Sig1977
Hi Sparky77,
Outstanding
Thank you for responding.
Where did you purchase the bolt? / Salvage yard?
Mike
Old May 18, 2017 | 07:46 AM
Alan 71's Avatar
Alan 71
Hi Mike,
In many cases you don't need the bolt.
Often if you smear some heavy grease on the rod and slip it into position it stays in place on its own while you bolt the fuel pump in place.
Maybe?
Regards,
Alan
Old May 18, 2017 | 08:16 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Originally Posted by Sig1977
Hi Sparky77,
Outstanding
Mike
Hardware store, get a grade 5 bolt. I also use a copper washer for sealing. T
Old May 18, 2017 | 09:43 AM
bradleyb66's Avatar
bradleyb66
Originally Posted by Alan 71
Hi Mike,
Maybe?
Regards,
Alan
I think he is missing the original bolt, and not trying to use the bolt to hold the rod in place during pump installation. I was surprised to find mine missing also last year when I replaced the fuel pump - it explained the slight oil leak I was having (although I was really surprised that it didn't leak more with the bolt missing).
Old May 18, 2017 | 10:04 AM
Sig1977's Avatar
Sig1977
[QUOTE=bradleyb66;1594763718]I think he is missing the original bolt, and not trying to use the bolt to hold the rod in place during pump installation. I was surprised to find mine missing also last year when I replaced the fuel pump - it explained the slight oil leak I was having (although I was really surprised that it didn't leak more with the bolt missing).[/QU
That is correct. Mine is missing. I to could not figure where I was leaking oil to include oil on my lower radiator hose to the water pump.
Read some articles stating oil can spray out at higher RPM.
Old May 18, 2017 | 10:06 AM
Sig1977's Avatar
Sig1977
Hi, was able to find the correct bolt but only in 1" not the 1/2 needed
Thanks,
Mike
Old May 20, 2017 | 06:42 PM
sparky77's Avatar
sparky77
got mine a Ace Hardware
To Missing Bolt
