Dead-simple, fool-proof, one-man break bleeding??!?
Old May 24, 2017 | 01:44 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Default Dead-simple, fool-proof, one-man break bleeding??!?
These have to be too good to be true, right?
-Just replace the 6 bleeder valves for $30 in our C3 brake systems with these one way valve bleeder valves that only allow fluid out and not air back in- then just crack them open and mash on the pedal for 3-6 pedal pushes per valve and you've bled your brakes?!?
I tried the stupid mity vac, the pressure bleeders have just too many complaints of them not fitting up to the master cylinders well for me to bother with but these seem dead simple.
What say, Ye?
http://www.jegs.com/i/Russell/799/63...nO8BoCnfPw_wcB
Adam
Old May 24, 2017 | 01:50 PM
juanvaldez's Avatar
juanvaldez
Speedbleeders, I've used them on lots of cars and motorcycles. They work. The Motive pressure bleeder works better.
Old May 24, 2017 | 01:58 PM
Edward M's Avatar
Edward M
5th Gear
What say, Ye?
Adam
This method works great. I just flushed my system using this method. One person brake bleed/system flush for less than $5.00
Old May 24, 2017 | 02:22 PM
xpoc454's Avatar
xpoc454
Never tried speed bleeders before but it sounds pretty good.
Old May 24, 2017 | 02:29 PM
Alan 71's Avatar
Alan 71
Hi Adam,
I think the speed bleeder description ignores the reality that the air in the lines isn't just waiting right at the bleeder… it's back 2-4-6-8' from the bleeder…. so all that fluid needs to come out through the bleeder before the last of the air is removed.
If speed bleeders were THE answer there'd be no need/market for other bleeding methods.
Regards,
Alan
Old May 24, 2017 | 02:55 PM
hzz's Avatar
hzz
Originally Posted by Alan 71
Hi Adam,
Regards,
Alan
Motive pressure bleeder works great....just clamp it on to the master cylinder tight.
Old May 24, 2017 | 03:55 PM
REELAV8R's Avatar
REELAV8R
What say, Ye?
Adam
They work for a while. Problem is you need to add sealer (red stuff you see in the pic) to the threads so that air is not sucked past the threads when they are loosened. So yes they work as long as the threads are sealed.
Read reviews here:
Amazon Amazon
Watching that video I think the sealant could be put on the threads of standard bleeders and the one person method could be used. His bleeders were pretty tight, probably because he or the PO never used them before, so they seemed to not suck air around the threads.
Had the fluid been flushed regularly he probably would not need to be changing the calipers in the first place.
My bleeders are used and looser and would definitely suck air around the threads.
Old May 24, 2017 | 09:08 PM
C3 4ME's Avatar
C3 4ME
Motive brake bleeders are not that much trouble. It's what I use for my 79 and I've never had better braking performance. As I'm sure you've read, I did as others suggest and have never used the chains that come in the kit. I've used bar clamps and large C clamps to get a good seal on the master cylinder. Once you've got a good seal, just open a bleeder and wait for the fluid to start running out, then watch the fluid flow until you have no more air bubbles. To me, couldn't be much easier.
Old May 26, 2017 | 03:22 PM
TCracingCA's Avatar
TCracingCA
Because you spelled Brakes wrong (breaks), I have my doubts about you!
Old May 26, 2017 | 04:11 PM
COOLTED's Avatar
COOLTED
They work. its a good deal. Its soooo easy.
Old May 26, 2017 | 04:27 PM
juanvaldez's Avatar
juanvaldez
They a 7 bucks apiece. C7 takes 8!
Old May 26, 2017 | 06:27 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
BINGO!!!
I took them off my C-5, for exactly THAT reason. However, I think that about 4-5 wraps of Teflon tape, on the threads of the bleeders, might seal them tightly enough, so they wouldn't suck any air.
To Dead-simple, fool-proof, one-man break bleeding??!?
