strange cooling problem
Old Jun 6, 2017 | 07:50 AM
oldguy's Avatar
oldguy
Default strange cooling problem
Cooling system works very well--190ish in town, 180 highway--with the heater core in the circuit. Remove the heater core (turn off the heater) temp rockets to 235-40. Belts squeal like an abused hog. In traffic, highway, everywhere. Open heater core-temp drops back to normal, squeal stops, all in about 20 seconds!! Is it possible to hydro-lock a water pump? Missing some kind of by-pass? I'm confused.
82 Corvette
Dart SHP 412
AFR 195 comp
Clay Smith 3102 221 cam
Weiand Team G pump
Robert Shaw type 180* thermo.
Eldebrock XT+EFI
Dewitt rad
Spal fans
Painless controller
Old Jun 6, 2017 | 09:09 AM
Revi's Avatar
Revi
Sounds like you're missing a by-pass or it's not working. With the heater core off-line you're not getting any water flow through the system.
Old Jun 6, 2017 | 09:36 AM
oldguy's Avatar
oldguy
Kinda-sorta figured that out
Where would this mysterious by-pass be located? All the parts seem to be pretty much standard configuration, has a plugged port on top of pump, heater feed out the side of the pump, return into intake--would appear to be normal setup. Something different about Dart SHP 400
block or Wieand Team G pump? AFR heads? Tee off heater return into top port on pump? Really confused.
Old Jun 6, 2017 | 09:37 AM
Revi's Avatar
Revi
The mysterious bypass should be before the heater core.
A picture or two of what you have may help.
Old Jun 6, 2017 | 09:47 AM
oldguy's Avatar
oldguy
I'll get some pics then try to figure out HOW TO POST THE DAMN THINGS
Old Jun 6, 2017 | 10:06 AM
Cooter Tech's Avatar
Cooter Tech
Are they electric fans and are they turning in the proper direction? Is your air dam installed?
Old Jun 6, 2017 | 10:31 AM
oldguy's Avatar
oldguy
Yes and yes. Cools very well with heater core in circuit.
Old Jun 6, 2017 | 10:58 AM
Cooter Tech
Put your pictures in a folder. When you reply click on attachments. A window opens (manage attachments), select chose file. Go to your photo folder, select picture, repeat if more than one picture. Lower right corner select upload, wait for pictures to populate. Minimize the manage attachments, don't close it. On main screen choose preview post, pictures should show up. If ok, select submit reply. Real simple right?? It is once you get used to doing it.
Old Jun 6, 2017 | 11:00 AM
oldguy's Avatar
oldguy
I'm trying
Old Jun 6, 2017 | 11:21 AM
Mr D.'s Avatar
Mr D.
I don't see water running or not running through the heater core causing a 60 degree swing in temp.
Old Jun 6, 2017 | 11:35 AM
oldguy's Avatar
oldguy
Yeah--me neither. But that is what is happening. Some discussion about a missing by-pass. Possibly from top of pump to port on manifold over by heater return. Whatever is going on causes the pump to lock up hard enough to make TWO belts squeal like a banshee.
Old Jun 6, 2017 | 11:46 AM
Revi's Avatar
Revi
There should be a valve inline between the water pump and the heater core (vacuum operated?).
When you turn your Heater OFF, the valve is most likely blocking all water from flowing. Liquids don't compress. With the water flow blocked, the water pump is trying to compress water into the heater hose and it can't do that, the water pump comes to a grinding stop and there is no water "flow" through the engine. The water is just sitting still in the engine/system.
Did this problem just start out of the blue or did you do something to the car and then the problem occurred?
It certainly seems like the heater core is inline with the engines coolant system and when the heater core is turned OFF you are blocking all flow through the engine.
Old Jun 6, 2017 | 11:58 AM
oldguy's Avatar
oldguy
Kinda-sorta figured that out too.
Question is will a by-pass hose from pump to intake do what needs to be done and still pass enough coolant thru the heater to make heat on a cold day. Don't drive much in cold- tires absolutely hate cold pavement- but still might need de-foggers some times. Some what less confused now
Trying to get ready for another dyno run. A little tweak here and there might be good for 10-15? hp or more??? Stay tuned.
Actually,in hindsight, problem has been here form the git-go. First start up belts made major racket. Eventually quieted down, but then opened the heater to purge air and never shut it off again until we started getting serious about tuning- Again. Didn't really notice any extra heat so just left it on. Shut it off because we could and the worms were out of the can!
Old Jun 6, 2017 | 12:33 PM
Cooter Tech
The only thing in the 3/4 inch heater hose is a shut off valve. The 5/8 inch hose goes directly to the heater core. Could there be a problem with your radiator? Could the lower radiator hose be collapsing?. I am running the 78 with heater core bypassed until I change out leaking heater core.
The center of your water pump that is plugged might be part of the bypass, if it is a big block.
http://www.hotrodders.com/forum/bbc-...ke-195057.html
Old Jun 6, 2017 | 12:45 PM
gungatim's Avatar
gungatim
assume it's a small block?
which version of the Team G pump do you have, there are several.
are you using a spacer on the pump? is it on right, or is it blocking the internal bypass hole from the pump to the block?
possible the bypass is blocked, AND the thermostat is backwards or not functioning properly leaving low flow with the heater core blocked (which when open functions as a bypass as well).
is the pump correct rotation?
Old Jun 6, 2017 | 12:54 PM
oldguy's Avatar
oldguy
Have a look back at post#1. Pretty much describes the whole situation. No problem at all with cooling as long as the heater core is in the system. Yes, the 5/8 hose goes directly from core to manifold. It would seem that a hose from the top of the pump to the port on the manifold just the right of the heater return would by-pass the blocked 3/4 hose. No?
Old Jun 6, 2017 | 01:01 PM
Revi's Avatar
Revi
It seems like your water pump isn't pumping any water directly through the engine block and all the water must first pass through the heater core before it gets to the engine block.
Sounds silly, but does explain the temp rise, belt squeal, etc. when the heater core is turned OFF.
To strange cooling problem
Old Jun 6, 2017 | 01:12 PM
oldguy's Avatar
oldguy
Thanks for the reply. Team G pump #9221 Using 3/16 spacers for 5-13/16 length. How do you put it on wrong? I see nothing to indicate any kind of blockage. Obviously the by-pass is blocked, I just don't see where or how. Thermo must be in right because it cools really well when the heater is in the circuit. Rotation is correct. Stand-alone by-pass like big block a possibility?
Old Jun 6, 2017 | 01:17 PM
oldguy's Avatar
oldguy
Yes, yes it does!! So now the question. So is the problem the Dart block, AFR heads or Weiand pump? Is the answer as simple as a by-pass hose ala big block? Getting confused again.
Old Jun 6, 2017 | 01:59 PM
Cooter Tech
Any chance your fans are cycling with your heater controls? I have tried the heater core trick whenever my car overheats, and it made very little if any difference in engine temps.
