Water Leak
Old Jun 10, 2017 | 06:21 PM
V4motorsports's Avatar
V4motorsports
Default Water Leak
My 71 convertible is leaking water into the interior along the back wall. There are holes behind each hinge for the deck lid. Do those holes lead anywhere.
I don't believe the water is leaking under the gasket. The carpet on the back wall is completely soaked.
Need to find the leak before I replace the carpet.
Thanks in advance
Russ
Old Jun 10, 2017 | 07:19 PM
Alan 71's Avatar
Alan 71
Hi Russ,
Is it possible that one of the rubber drain tubes for the astro ventilation plenums in the rear deck are leaking water into the rear compartment?
Regards,
Alan
The lowest arrow in the photo points to the drain.
The other arrows point to fiberglass plenum and the block-off plate used on cars with a/c.
Old Jun 10, 2017 | 08:07 PM
oldboat's Avatar
oldboat
on my 69 convertible if the drains get clogged water fills the rear plenum areas and leaks past the astro vent flaps.
clearing the drains always fixes the problem
Old Jun 10, 2017 | 08:56 PM
V4motorsports
Originally Posted by Alan 71
Hi Russ,
Regards,
Alan
Alan,
Sorry, forgot to mention that the car is A/C equipped. So, if I'm not mistaken, there are no rubber drain tubes.
Russ
Old Jun 10, 2017 | 08:58 PM
V4motorsports
Thought A/C convertible cars didn't have astro vent flaps.
Russ
Old Jun 10, 2017 | 10:17 PM
oldboat's Avatar
oldboat
sorry didn't know it had a/c
Old Jun 11, 2017 | 06:19 AM
V4motorsports
Yeah....I forgot to add that.
Russ
Old Jun 11, 2017 | 07:19 AM
Alan 71's Avatar
Alan 71
Hi Russ,
You're right.
I always confuse the time period during production when the rear bulkhead was moved which eliminated the need for the rubber drain tubes on convertibles.
Sorry!
Regards,
Alan
Old Jun 11, 2017 | 03:13 PM
V4motorsports
Guess I'll just have to run a hose over the deck lid to see where its leaking.
Thanks for all the help.
Russ
To Water Leak
