Need info on my motor
You have to pull the valve cover to see the part number.
As far as fuel line and filter I would bend and falr by own line and route it like the factory did.
I would ask Lars here for his paper on using a late model fuel filter with fittings that you can use. Best setup I've seen.
https://www.corvetteforum.com/forums...b-set-ups.html
https://www.corvetteforum.com/forums...el-filter.html
