Exaust
Old Jun 18, 2017 | 09:06 PM
Anthony Ranno's Avatar
Anthony Ranno
Navigator
Default Exaust
Where can I find a real duel exaust system for my 1980 corvette manifold back no y pipe or cat. I want a real duel exaust not the y pipe cat factory junk exusast. From manifolds back not headers I do not have headers.
Once again where can I find a true duel exaust system for my 1980 vette? No y pipe no cat. From my factory exaust manifolds back
Old Jun 19, 2017 | 08:13 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
First of all, depending on where you live, deleting the catalytic converter may be illegal. Just something to consider. Secondly, and I'm not positive, but I think that at some point, the transmission crossmember may have been modified, such that a drivers side exhaust pipe may not be able to be routed through there. I do know that it was done on some GM cars, but as I said, I'm not positive about the Corvette.
Or, you could always go with sidepipes..........
Old Jun 19, 2017 | 08:31 AM
Street Rat's Avatar
Street Rat
Hi Anthony,
On my '81 I had to modify the cross member to get true dual exhaust down the passenger side. I later purchased a cross member from Bow Tie Overdrives that allows a variety of pipe sizes and direction.
Try Corvette Central for the exhaust system.
SR
Old Jun 19, 2017 | 10:15 AM
Anthony Ranno
Navigator
Not concerned with legalitys the catalytic converter is already in the scrap pile.
Old Jun 19, 2017 | 02:28 PM
rklessdriver's Avatar
rklessdriver
Corvette Central mfgr's a dual exhaust system that bolts right on 80-81's.
http://www.parts123.com/corvettecent...50g&ukey=19645
Other option is to change the trans crossmember or modify it to be more like a 1979 and earlier type and use an exhaust system designed for the earlier cars.
Will
Old Jun 19, 2017 | 10:43 PM
Anthony Ranno
Navigator
Originally Posted by Street Rat
Hi Anthony,
SR
Passenger side? That's the side the exhaust goes down factory I'm pretty sure the drivers side is the problem
Old Jun 20, 2017 | 12:30 AM
ncbuckeye3's Avatar
ncbuckeye3
Where do you live? I'm in NW Arkansas and I just went to a local muffler shop with my 78 and he put dual exhaust in with two Flowmasters and it sounds awesome. Less money than basically the same thing from one of the vendors online.
Old Jun 20, 2017 | 12:58 AM
Z06LMB's Avatar
Z06LMB
Street rat and rklessdriver are correct
Old Jun 20, 2017 | 01:02 AM
Anthony Ranno
Navigator
I live in tampa Florida. The problem with the 1980 is the crossmember it's designed for the y pipe even a shop would have to modify it or use an older one from an older car and I don't want both pipes running down the passenger side.
Old Jun 20, 2017 | 01:06 AM
Anthony Ranno
Navigator
They said passenger side has to be modified I'm sure on mine it's the drivers side of the x member that needs to be changed to allow a pipe because the stock exhaust runs on the passenger side the drivers side of the x member will not allow a pipe.
Old Jun 20, 2017 | 02:12 AM
Z06LMB's Avatar
Z06LMB
Sorry for the confusing reply.
I meant for recommending Corvette Central for dual exhaust parts on the '80 to 82's.
Last summer I saved a buddy 50% over CA with using show discounts and free shipping for the same problem you have with the X pipe with duals and right side fitment you have but on an 81. Up too late tonight
To Exaust
