vacuum headlight doors
Old Jun 30, 2017 | 01:04 PM
409/409's Avatar
409/409
Default vacuum headlight doors
My 1974 headlight doors open quickly and close quickly like they should, except when closed they stick up about 3/4". I can push them down, but they stick back up against what feels like is either spring pressure or air pressure. Is there an adjustment? What is the fix for this?
Thanks in advance.
Old Jun 30, 2017 | 03:34 PM
Alan 71's Avatar
Alan 71
Hi 409,
It sounds like you're pushing against the rubber plenum seal inside the actuator.
What's odd is that they're both doing the same thing.
Normally I suggest that the 'clevis' that's on the end of the rod that comes out of the actuator needs to be adjusted so the full movement of the plenum is enough to completely close the doors.
There is an 'adjustment' for the closed position of the door but it's unusual but again… strange that it's both of them.
Is this a new problem?
Have you done any work on the headlight system recently?
Regards,
Alan
Old Jun 30, 2017 | 05:01 PM
409/409's Avatar
409/409
Alan,
I really appreciate your quick response. I found the problem. Bubba installed fog lights behind the grill and the headlight doors were hitting them. I removed them and everything is good.
Old Jun 30, 2017 | 05:17 PM
Alan 71's Avatar
Alan 71
Hi 409,
Well !!, an easy fix!
Hope you said a little prayer of thanksgiving!
Regards,
Alan
To vacuum headlight doors
