Need help/info on getting 68 vette running!
OH BOY....The MAIN thing I got out of what you wrote ...in regards to mechanical information is that the engine 'locked-up'.
Not knowing if the car is an automatic or manual...I would take the time FIRST OFF in verify if I can manually spin (rotate) the engine by using a flywheel turner tool...which is why knowing if it is an automatic transmission or not does make a difference.
DUB
The motor just needs the oil changed, the battery replaced and the fuel tank drained. Then you can either poor a little fuel down the carb throat and turn it over or you can pull all the plugs and squirt a tiny amount of marvels mystery oil in there and let it soak for a day, then manually turn it over before replacing the plugs and then pouring a tiny amount of fuel down the throat and turning it over. Good luck
Brian
drained gas tank, replaced all rubber fuel lines.
pulled plugs put ATF in cylinders let it sit. turned over by hand first to make sure it was free. think I let it sit for 3-4 days. put new plugs in.
I had to rebuild the carb, as it leaked
as soon as my engine started, the fuel pump leaked, I had to replace it.
After it was running the first time, I replaced all ignition components.
I personally am not a fan of cranking an engine that has sat as long as this due to a 'dry start up'.
YES..I do have priming tool that can allow me to get the oil to circulate throughout the engine without have to turn the engine to do so. So..that is WHY that is my method of choice.
And what amazes me...in the countless engines I have started that were fresh rebuilds. The amount of time that oil pump is turning quite quickly and how long it takes for me to see any oil get to the FIRST rocker arm.
YES..I understand that this is not a fresh rebuilt engine...and I am sure that there may still be oil lingering in some components.....but...I have to err on the side of caution when I am dealing with customers engines. Removing the distributor and setting it back in and getting it cranked is not beyond my capabilities and not that hard to do.
DUB
Where and how the car has been stored will have an effect. Mine was stored in a typical garage, ambient temperatures in New England. I did 'seal' the intake and exhaust to limit the amount of moist air that would make its way into the engine.
The engine was pulled giving me much better access that would have been the case with it still in the car.
I removed all the plugs, drained the oil, and then poured an industrial quantity of KROIL into each cylinder till it ran out the plug hole with the engine in a stand and one bank vertical.
I left it sit for a week.
Then I did the other bank, rotated to vertical and let it sit another week.
I removed the flywheel and replaced two of the bolts with longer ones, which permitted me to use a very long socket extension as a lever, and it turned over quite easily.
The cooling jacket/passages were all full of coagulated gunk.
I was particularly (perhaps needlessly) concerned about the valve springs as they had had no exercise for 34 years.
After rebuilding, we used an oil pump drive with an electric drill to run the pump until oil showed up 'everywhere' and 80 PSIG registered on the gauge.
This was repeated Saturday when it was first started.
ALL the plumbing in the car was replaced. Every component of the brake system was replaced. The gas tank was replaced. All this stuff had 'YUCK' in it.
Not knowing where you are located, perhaps the plumbing in your car is OK from a rust standpoint, but I'd be suspicious of the 'YUCK' aspect contained within.
In your case, not having real access to the flywheel, after doing all that I did with respect to lubing the cylinders, spinning the oil pump, etc, I'd put it in fourth and, with a few friends, rock the car back and forth. The complicating factor is that very likely there's been an accumulation of rust on the rotors, etc, and the brakes will be bound up tight. Maybe not - in the case of my car, only one wheel was so afflicted, but it prevented us from pushing the car...
Good luck - you are in possession of a family treasure!
Hell, if you're close to any of us we'll line up to lend you a hand, a tool or three, a few saved for the future parts...
For a '68, a Chilton or Haynes manual would be a great reference. Wonderfully reliable car once you get it in order. Oh the fun!
