damaged fiber optics
Old Jul 19, 2017 | 08:09 PM
68Rick's Avatar
68Rick
Default damaged fiber optics
I have a 68 with damaged fiber optics. The damage is inside at the fiber optic console lenses. The some of fiber has been cut off and a few of the ferrules are missing. I need the ferrules for the inside not the outside. Does anyone know where to find them?
Old Jul 20, 2017 | 12:17 AM
Greg's Avatar
Greg
Just another Corvette guy
Rick, if you're not going to replace the whole fiber optic harness, I have repaired them before simply by using the same heat shrink that you would use to cover a wire splice. Very inexpensive and available at any parts store. Run about an inch of heat shrink, heat it so it's nice and tight, then cut it off flat with a new razor blade. This should give you a pretty decent lighted edge. You can fasten it in the lens in any number of ways from tape to epoxy. I use a little 3M emblem tape. The ferrules tend to come loose.
Old Jul 20, 2017 | 01:33 AM
68Rick's Avatar
68Rick
Thanks Greg. I figured I would have to get a little creative on the inside. My fiber seems to be in good shape except for a couple ends that was cut off inside. If I find a piece that's bad, i believe it can be replaced with the simplex 1mm E1000. I believe its about 55 cents per foot. The ferrules at the light are easy to find. The ones inside are a different story.
Old Jul 20, 2017 | 04:32 AM
hunt4cleanair's Avatar
hunt4cleanair
Another option would be a fiber optics repair kit such as that sold through Mid-America Motor Sports
Fiber Optic Repair Kit
Old Jul 20, 2017 | 10:25 AM
Alan 71's Avatar
Alan 71
Hi 68,
Is this the ferrule you're looking for?
Regards,
Alan
Old Jul 20, 2017 | 11:59 AM
68Rick's Avatar
68Rick
Yep, that's the one.
Old Jul 20, 2017 | 12:11 PM
rays699's Avatar
rays699
corvette central has them
Old Jul 20, 2017 | 12:29 PM
Alan 71's Avatar
Alan 71
Hi r,
I see the ferrules for the lamp end of the cable but not the lens end.
Do you have the CC part number?
Regards,
Alan
Old Jul 20, 2017 | 12:53 PM
rays699's Avatar
rays699
Originally Posted by Alan 71
Hi r,
Regards,
Alan
page 46 663069 68-71 pr. $20.95
Old Jul 20, 2017 | 02:00 PM
Alan 71's Avatar
Alan 71
Hi r,
That number appears to be the lens.
I thought Rick was looking for the cable 'ferrule' for that end of the cable.
Maybe I misunderstood his post.
Regards,
Alan
Old Jul 20, 2017 | 06:00 PM
68Rick's Avatar
68Rick
Hi r,
Regards,
Alan
You are correct Alan. I'm looking for the ferrule for that lens. I've found every part except that. The entire harness could be built if those ferrules could be found. I'm sure there is another way to secure the fiber to the lens if they can't be found. But, my fiber seems to be good except for the missing inside ferrules.
Old Jul 20, 2017 | 06:21 PM
Alan 71's Avatar
Alan 71
Hi Rick,
Obviously the purpose of the ferrule is to hold the cable in the lens's tubes.
BUBBA ALERT!!!!
Could you place the cable into position and then wedge something like a piece of tooth pick in the tube to hold the cable in place? Once the shifter plate is back inlace on the console there's really no pressure on the cable to make it want to back out of the tube?
I can't believe I just wrote that!!!
Hopefully you'll be able to find a source for the ferrules!
Regards,
Alan
You KNOW there have been lots of 68-71 forward lighting harnesses discarding with at least a few of those ferrules still on it! I reused my forward harness so can not be any help.
Old Jul 20, 2017 | 08:46 PM
loup68's Avatar
loup68
Army
I do not have access to my attic to check if I have any. They just poured cement in my old existing garage, with the pull down stairs, today. How many ferrules do you need? Lou.
Old Jul 21, 2017 | 04:37 PM
68Rick's Avatar
68Rick
After a close look, I want to trim each one and polish the fresh cut end.
This is the fwd harness. I need to replace all of the ends here.
Old Jul 21, 2017 | 11:25 PM
TimAT's Avatar
TimAT
I was going to suggest a trip to the hobby shop for a piece of brass tube that will just fit the fiber. Looks like you found a fix.
Old Oct 18, 2017 | 03:47 PM
TSKieffer's Avatar
TSKieffer
5th Gear
Default Fiber Optic Repair and Replacement Parts
I found an excellent source for Fiber Optic Repair and Replacement Parts following the <link> below:
http://www.zip-corvette.com/68-82-c3...year/1969.html
To damaged fiber optics
